What Are Pools Made Of?
i have a few questions about pools...
What type of material are pools made of? What kind of paints are used on pools. Reason for asking is becuase i have potential client that wants the paint blasted off his pool. its a 20x40 (havent seen it yet, but thats what im told. BTW, i wont recoat the pool, only blasting to be done. Thanks Rich |
Re: What Are Pools Made Of?
concrete shell
plaster or paint (latex or epoxy) plaza put my response out here too. thanks btw if your a "blaster" I'm sure you can find plenty of work through pool construction & service companies. who are qualified to drain & maintain an empty pool for you. ray
......Less with the jaw & More with the paw..... |
generally, painters etc, should steer away from painting ig pools. reason being the draining & maintaining of an empty concrete pool requires specializied skill & equipment. it is not uncommon to find the pool in a high water table. while empty the pool has the potential to raise out of the ground or crack. we avoid this by drilling through the shell & relieving hydostatic valves....
I highly doubt your insurance covers pool movement & cracking. I don't think it worth risking taking a hit for pool demolition & replacement. if you do this job, ill walk you through it. once again, cut & paste our private message as a thread in pool forum, the others will help too. ray Ray, so your saying if i were to blast this pool, i would need drilling through the shell & relieving hydostatic valves? What exactly is this? Im guessing its something i cannot do. I think the blasting part would be easy, i would treart like concrete. I didnt think any other procedures were necessary, i guess i was wrong. |
the chances are 50/50 depending on the jobsight.
I shoot holes into every one I drain. half the time I need them, to relieve hydrostatic pressure.
Trade: Siding & remodeling
i have found there are just some jobs that aint worth the time.... but u never know till u try it
#6 | |
Trade: contractor
Re: What Are Pools Made Of?Quote:
DO NOT get into taking liability for an empty shell. if you're working as a sub for a pool co - let them worry about the draining. if you're working for a HO - let them worry about that |
#7 | |
ray
i took a look at the pool, pool company already drained...prepped
i only have to blast. Ray, do you know what others in your area charge to blast? Also i think i may need some help calculating the sq.ft of this pool.. lol |
I hear 1400-1700 average. then you have to see more for a spa or anything else. I assume these are repaints not plaster jobs.
#10 | |
Ray, i have to assume its a full plaster job because they chipped the entire surface of the pool (assuming you know i what i mean by chipped right) What size of a pool would you consider to be average? |
650 to 800 sqft
Ray,
Do you think you can tell me the total sq.ft of this pool? Its an irregular shape 12' 18' 14' 21' 15' 15' about 9' deep at the deep end. 3 stairs |
#13 | |
Trade: contractor
irregular, ill say it depends if you're pricing by surface area (of water) or by actual surface (i.e. walls and floor) if those measurements came from measuring the perimeter - you've got a per of 96 lin ft as a general rule, (in my opinion) - something with a perimeter like that is going to be around 500 sq. ft. NOT ALWAYS - just in general. now - your depth is going from 3 to 9 (avg depth - 6 ft) - the actual surface-surface area is going to be around 3000 figuring in the stairs would be nominal at this point. like i said - depends on how you're pricing. I look at water surface area. So I'm never concerned about walls (unless im figuring out gallons of water) hope it helps |
I take the longest & widest point to fig sqftg. granted the figure will be high, but that's my tip$$$!!!!
& besides that's how they charge us for covers....... I don't think sqft is a good way for you to price.... just price yourself a nice chunk, if you can show up you will get the work. this is a luxury biz. ray
dirt
i want to price it by actual surface area, floors and walls needs to be blasted. So you are saying i have around 3000 sq.ft of blasted area? Ray, you are right, i wish i had the experience on how price it out right, but since its my first pool, i kinda need a guide on how its priced. After this job, i'll know exactly. Rich |
Custom Builder
Post a pic or diagram Plaza, I'm sure that would help.
Bob |
Thanks for all the help, job booked.
#18 |
right on plaza!!!!!
hope you wacked 'em good$
#19 |
im not sure if can say that, i matched a competitors estimate. I know some people will say i shouldnt have, but when you think about, its my first job. i have no clue how to price it and what to expect. If i win, i win, if i lose, i am willing to accept it.
#20 |
Trade: contractor
bad thing about matching a competitors price (on first several jobs)
they've already learned to be systematic and efficient ... know what i mean?? |
| Landscapers building the best pools?? | ruskent | Pool Construction & Enclosures | 11 | 07-12-2009 12:55 PM |
| How to learn to install guinte pools? | Troland | Pool Construction & Enclosures | 3 | 06-18-2007 10:06 PM |
| Help on Insurance - Occurance premium, Occurance with Sunset, or Claims Made | DoubleJ | Business | 6 | 05-01-2007 01:12 PM |
| How many pools a year before you buy a excavator?? | ruskent | Pool Construction & Enclosures | 3 | 02-25-2007 07:31 AM |
| Where are your tools made? | Chris G | Tools & Equipment | 2 | 11-07-2006 11:50 AM |
