Trade: swimming pool
Vgb.
I am surprised I haven't seen any comments about VGB! How is everyone who is responsible for commercial pools making out with getting compliant covers? Is any one having issues with local VS Federal requirements?
The day I stop learning is the day I die! Last edited by nadtwins; 02-05-2009 at 01:47 PM. |
Trade: Swimming Pool & Excavating Contractor
Re: Vgb.
We do not do much commercial work, so we have not had many issues yet. We'll see how the spring goes. You must be selling the grates and SVRS's like they're going out of style!?
Scott Is this going to be expensive? It's all relative. |
Trade: In-ground Swimming Pool Contractor
Re: Vgb.
we havent had much work for this cause our health dept is against vgb.
#4 | |
Re: Vgb.Quote:
#5 | |
Re: Vgb.Quote:
As if your health department has a choice!!!!!!!!! Above and beyond that god forbid there is an incident in a commercial pool that is not in compliance with VGB that you are taking care of--- you will with out a doubt be doing Jail time!
The day I stop learning is the day I die! |
Re: Vgb.
The tailors are coming to measure Gunite Pool Guy up for a striped jump suit.
Don't ignore the topic whether you work on commercial pools or not. As a professional swimming pool contractor/service company you should make it a priorty to stay abreast of the national industry issues.
#7 | |
Re: Vgb.Quote:
The grates go out faster than they are coming in! If you need some for this summer you should order them now. One thing to keep in mind the big guys grate has a horrible flow rate @ 1.5' per second. So be careful which grate you chose make sure that it can accommodate the full flow of the system @1.5' per second if everything else is blocked. If your interested there is a code class On Tuesday that will cover all the new codes both residential and commercial, the speakers that are lined up are pretty good!
Re: Vgb.
You guys are absolutley right! And believe me when i tell you that all of our new pools and renovations comply with fed laws. It does not effect us so much because we are not a service company. All i was saying is that in my neck of the woods its not being strictly enforced.
Re: Vgb.
We actually started doing VGB upgrades last summer on municipal pools. The biggest problem/slow-down was the availability of ANSI certified covers. They are coming through the system pretty well now. This work along with filter plant replacements and UV systems is keeping us rather busy.
Sean
Re: Vgb.
If you guys don't mind - what is VGB / the new regs you are talking about? Thanks
#11 | |
Trade: Specializing in residential remodeling
Re: Vgb.Quote:
| The Following User Says Thank You to j_builder For This Useful Post: | SLSTech (03-01-2009) |
Re: Vgb.
Here is the compleate lawwritten
I will have to post it in two sections TITLE XIV--POOL AND SPA SAFETY
SEC. 1401. SHORT TITLE. This title may be cited as the `Virginia Graeme Baker Pool and Spa Safety Act'. SEC. 1402. FINDINGS. Congress finds the following: (1) Of injury-related deaths, drowning is the second leading cause of death in children aged 1 to 14 in the United States. (2) In 2004, 761 children aged 14 and under died as a result of unintentional drowning. (3) Adult supervision at all aquatic venues is a critical safety factor in preventing children from drowning. (4) Research studies show that the installation and proper use of barriers or fencing, as well as additional layers of protection, could substantially reduce the number of childhood residential swimming pool drownings and near drownings. SEC. 1403. DEFINITIONS. In this title: (1) ASME/ANSI- The term `ASME/ANSI' as applied to a safety standard means such a standard that is accredited by the American National Standards Institute and published by the American Society of Mechanical Engineers. (2) BARRIER- The term `barrier' includes a natural or constructed topographical feature that prevents unpermitted access by children to a swimming pool, and, with respect to a hot tub, a lockable cover. (3) COMMISSION- The term `Commission' means the Consumer Product Safety Commission. (4) MAIN DRAIN- The term `main drain' means a submerged suction outlet typically located at the bottom of a pool or spa to conduct water to a recirculating pump. (5) SAFETY VACUUM RELEASE SYSTEM- The term `safety vacuum release system' means a vacuum release system capable of providing vacuum release at a suction outlet caused by a high vacuum occurrence due to a suction outlet flow blockage. (6) SWIMMING POOL; SPA- The term `swimming pool' or `spa' means any outdoor or indoor structure intended for swimming or recreational bathing, including in-ground and above-ground 2 structures, and includes hot tubs, spas, portable spas, and nonportable wading pools. (7) UNBLOCKABLE DRAIN- The term `unblockable drain' means a drain of any size and shape that a human body cannot sufficiently block to create a suction entrapment hazard. SEC. 1404. FEDERAL SWIMMING POOL AND SPA DRAIN COVER STANDARD. (a) Consumer Product Safety Rule- The requirements described in subsection (b) shall be treated as a consumer product safety rule issued by the Consumer Product Safety Commission under the Consumer Product Safety Act (15 U.S.C. 2051 et seq.). (b) Drain Cover Standard- Effective 1 year after the date of enactment of this title, each swimming pool or spa drain cover manufactured, distributed, or entered into commerce in the United States shall conform to the entrapment protection standards of the ASME/ANSI A112.19.8 performance standard, or any successor standard regulating such swimming pool or drain cover. (c) Public Pools- (1) REQUIRED EQUIPMENT- (A) IN GENERAL- Beginning 1 year after the date of enactment of this title-- (i) each public pool and spa in the United States shall be equipped with anti-entrapment devices or systems that comply with the ASME/ANSI A112.19.8 performance standard, or any successor standard; and (ii) each public pool and spa in the United States with a single main drain other than an unblockable drain shall be equipped, at a minimum, with 1 or more of the following devices or systems designed to prevent entrapment by pool or spa drains that meets the requirements of subparagraph (B): (I) SAFETY VACUUM RELEASE SYSTEM- A safety vacuum release system which ceases operation of the pump, reverses the circulation flow, or otherwise provides a vacuum release at a suction outlet when a blockage is detected, that has been tested by an independent third party and found to conform to ASME/ANSI standard A112.19.17 or ASTM standard F2387. (II) SUCTION-LIMITING VENT SYSTEM- A suction-limiting vent system with a tamperresistant atmospheric opening. (III) GRAVITY DRAINAGE SYSTEM- A gravity drainage system that utilizes a collector tank. 3 (IV) AUTOMATIC PUMP SHUT-OFF SYSTEM- An automatic pump shut-off system. (V) DRAIN DISABLEMENT- A device or system that disables the drain. (VI) OTHER SYSTEMS- Any other system determined by the Commission to be equally effective as, or better than, the systems described in subclauses (I) through (V) of this clause at preventing or eliminating the risk of injury or death associated with pool drainage systems. (B) APPLICABLE STANDARDS- Any device or system described in subparagraph (A)(ii) shall meet the requirements of any ASME/ANSI or ASTM performance standard if there is such a standard for such a device or system, or any applicable consumer product safety standard. (2) PUBLIC POOL AND SPA DEFINED- In this subsection, the term `public pool and spa' means a swimming pool or spa that is-- (A) open to the public generally, whether for a fee or free of charge; (B) open exclusively to-- (i) members of an organization and their guests; (ii) residents of a multi-unit apartment building, apartment complex, residential real estate development, or other multi-family residential area (other than a municipality, township, or other local government jurisdiction); or (iii) patrons of a hotel or other public accommodations facility; or (C) operated by the Federal Government (or by a concessionaire on behalf of the Federal Government) for the benefit of members of the Armed Forces and their dependents or employees of any department or agency and their dependents. (3) ENFORCEMENT- Violation of paragraph (1) shall be considered to be a violation of section 19(a)(1) of the Consumer Product Safety Act (15 U.S.C. 2068(a)(1)) and may also be enforced under section 17 of that Act (15 U.S.C. 2066).
Re: Vgb.
here is the secound part!
SEC. 1405. STATE SWIMMING POOL SAFETY GRANT
PROGRAM. (a) In General- Subject to the availability of appropriations authorized by subsection (e), the Commission shall establish a grant program to provide assistance to eligible States. (b) Eligibility- To be eligible for a grant under the program, a State shall-- 4 (1) demonstrate to the satisfaction of the Commission that it has a State statute, or that, after the date of enactment of this title, it has enacted a statute, or amended an existing statute, and provides for the enforcement of, a law that-- (A) except as provided in section 1406(a)(1)(A)(i), applies to all swimming pools in the State; and (B) meets the minimum State law requirements of section 1406; and (2) submit an application to the Commission at such time, in such form, and containing such additional information as the Commission may require. (c) Amount of Grant- The Commission shall determine the amount of a grant awarded under this title, and shall consider-- (1) the population and relative enforcement needs of each qualifying State; and (2) allocation of grant funds in a manner designed to provide the maximum benefit from the program in terms of protecting children from drowning or entrapment, and, in making that allocation, shall give priority to States that have not received a grant under this title in a preceding fiscal year. (d) Use of Grant Funds- A State receiving a grant under this section shall use-- (1) at least 50 percent of amounts made available to hire and train enforcement personnel for implementation and enforcement of standards under the State swimming pool and spa safety law; and (2) the remainder-- (A) to educate pool construction and installation companies and pool service companies about the standards; (B) to educate pool owners, pool operators, and other members of the public about the standards under the swimming pool and spa safety law and about the prevention of drowning or entrapment of children using swimming pools and spas; and (C) to defray administrative costs associated with such training and education programs. (e) Authorization of Appropriations- There are authorized to be appropriated to the Commission for each of fiscal years 2009 and 2010 $2,000,000 to carry out this section, such sums to remain available until expended. Any amounts appropriated pursuant to this subsection that remain unexpended and unobligated at the end of fiscal year 2010 shall be retained by the Commission and credited to the appropriations account that funds enforcement of the Consumer Product Safety Act. SEC. 1406. MINIMUM STATE LAW REQUIREMENTS. (a) In General- (1) SAFETY STANDARDS- A State meets the minimum State law requirements of this section if-- 5 (A) the State requires by statute-- (i) the enclosure of all outdoor residential pools and spas by barriers to entry that will effectively prevent small children from gaining unsupervised and unfettered access to the pool or spa; (ii) that all pools and spas be equipped with devices and systems designed to prevent entrapment by pool or spa drains; (iii) that pools and spas built more than 1 year after the date of the enactment of such statute have-- (I) more than 1 drain; (II) 1 or more unblockable drains; or (III) no main drain; (iv) every swimming pool and spa that has a main drain, other than an unblockable drain, be equipped with a drain cover that meets the consumer product safety standard established by section 1404; and (v) that periodic notification is provided to owners of residential swimming pools or spas about compliance with the entrapment protection standards of the ASME/ANSI A112.19.8 performance standard, or any successor standard; and (B) the State meets such additional State law requirements for pools and spas as the Commission may establish after public notice and a 30-day public comment period. (2) NO LIABILITY INFERENCE ASSOCIATED WITH STATE NOTIFICATION REQUIREMENT- The minimum State law notification requirement under paragraph (1)(A)(v) shall not be construed to imply any liability on the part of a State related to that requirement. (3) USE OF MINIMUM STATE LAW REQUIREMENTS- The Commission-- (A) shall use the minimum State law requirements under paragraph (1) solely for the purpose of determining the eligibility of a State for a grant under section 1405 of this Act; and (B) may not enforce any requirement under paragraph (1) except for the purpose of determining the eligibility of a State for a grant under section 1405 of this Act. (4) REQUIREMENTS TO REFLECT NATIONAL PERFORMANCE STANDARDS AND COMMISSION GUIDELINES- In establishing minimum State law requirements under paragraph (1), the Commission shall-- (A) consider current or revised national performance standards on pool and spa barrier protection and entrapment prevention; and (B) ensure that any such requirements are consistent with the guidelines contained in the Commission's publication 362, entitled `Safety Barrier Guidelines for Home Pools', the 6 Commission's publication entitled `Guidelines for Entrapment Hazards: Making Pools and Spas Safer', and any other pool safety guidelines established by the Commission. (b) Standards- Nothing in this section prevents the Commission from promulgating standards regulating pool and spa safety or from relying on an applicable national performance standard. (c) Basic Access-Related Safety Devices and Equipment Requirements To Be Considered- In establishing minimum State law requirements for swimming pools and spas under subsection (a)(1), the Commission shall consider the following requirements: (1) COVERS- A safety pool cover. (2) GATES- A gate with direct access to the swimming pool or spa that is equipped with a self-closing, self-latching device. (3) DOORS- Any door with direct access to the swimming pool or spa that is equipped with an audible alert device or alarm which sounds when the door is opened. (4) POOL ALARM- A device designed to provide rapid detection of an entry into the water of a swimming pool or spa. (d) Entrapment, Entanglement, and Evisceration Prevention Standards To Be Required- (1) IN GENERAL- In establishing additional minimum State law requirements for swimming pools and spas under subsection (a)(1), the Commission shall require, at a minimum, 1 or more of the following (except for pools constructed without a single main drain): (A) SAFETY VACUUM RELEASE SYSTEM- A safety vacuum release system which ceases operation of the pump, reverses the circulation flow, or otherwise provides a vacuum release at a suction outlet when a blockage is detected, that has been tested by an independent third party and found to conform to ASME/ANSI standard A112.19.17 or ASTM standard F2387, or any successor standard. (B) SUCTION-LIMITING VENT SYSTEM- A suction-limiting vent system with a tamper-resistant atmospheric opening. (C) GRAVITY DRAINAGE SYSTEM- A gravity drainage system that utilizes a collector tank. (D) AUTOMATIC PUMP SHUT-OFF SYSTEM- An automatic pump shut-off system. (E) DRAIN DISABLEMENT- A device or system that disables the drain. (F) OTHER SYSTEMS- Any other system determined by the Commission to be equally effective as, or better than, the systems described in subparagraphs (A) through (E) of this paragraph at preventing or eliminating the risk of injury or death associated with pool drainage systems. (2) APPLICABLE STANDARDS- Any device or system described in subparagraphs (B) through (E) of paragraph (1) shall meet the requirements of any ASME/ANSI or ASTM performance standard if 7 there is such a standard for such a device or system, or any applicable consumer product safety standard.
Trade: Swimming Pool Costruction
Re: Vgb.
Don't forget that it isnt JUST about the grates! The grates must be properly sized to meet the flow requirements of the pool. In addition to the grates you have sumps that may require improvement. Finally you have the second layer of protection such as splitting drains, SVRS, unblockable drains, etc.
You should also keep a database of any drain fittings you sell or install. The Consumer Product Safety Commission posts recall notices on their website every day and I am sure that is coming to pool builders as well. You can't ignore it, it is the law of the land. I believe the max fine is set at $15m for willfully ignoring the VGBA. |
