Stone Affecting Water Chemistry
Old 08-13-2007, 10:32 PM   #1
dirt diggler's Avatar
Trade: contractor
Tscar's thread reminded me of something that has bugged me for awhile
im not talking like waterfalls - but more like actually setting stones in water (or on rolled beams in lieu of tile/coping).
i haven't come across anyone wanting to do this .... but may get the opportunity here this Fall on a new one coming up
so, after that longwinded explanation - my question is: will natural stones have any effects on the chemistry balance? if they are placed in the water???
Can't see that they would. If anything - it would be the other way around ... water affecting the rocks .... I've had rocks on the bottom of water falls below the waterline - hasn't affected chemistry. No calcium deposits (which i did warn/disclaim the HOs about)
dirt diggler is offline
Old 08-13-2007, 10:38 PM   #2
Tscarborough's Avatar
Re: Stone Affecting Water Chemistry
Waterfalls over limestone will push the PH more than immersed rocks, but neither will have much effect in a pool. In a pond, it is a consideration.
Tscarborough is offline
Old 08-13-2007, 10:42 PM   #3
ruskent's Avatar
Trade: Outdoor D/B
I remember reading something on some other site about saltwater hurting or damaging flagstone???
ruskent is offline
Old 08-13-2007, 10:48 PM   #4
Trade: contractor
let me clarify - not talking about water flowing over rocks on a waterfall
i mean rocks IN the pool
haha, man that statement, by itself and taken out of context is funny
Old 08-13-2007, 11:10 PM   #5
Either way, in a pool it won't matter, although some limestones will work as a sacrificial ph buffer, like a zinc on a boat shaft. The one thing they do that can be good is to provide calcium to the system, over and above the buffering capability. A lot depends upon your local water, though. For this area, I recommend granitic or sandstone rocks for PONDS, but I don't see it making a difference for pools.
Old 08-13-2007, 11:27 PM   #6
Custom Builder
Glasshousebltr's Avatar
add a little scotch.
Bob
Glasshousebltr is offline
Old 08-13-2007, 11:45 PM   #7
POOLMANinCT's Avatar
oxiderizers will sequester iron from some rocks, red water & stained plaster
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 08-15-2007, 06:07 AM   #8
Poolman's Avatar
Trade: Swimming Pool & Excavating Contractor
Depends on the rocks. In general the pools we work with which have rocks in the water are fine. Only thing to watch for like ray said is ...the iron factor. This will make a mess on your plaster surface.
Scott
Poolman is offline
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
Even When You Do It Right denick Excavation & Site Work 6 04-15-2006 06:04 PM
