Stains In Pool (Pictures Included)
Old 03-27-2008, 08:13 AM   #21
Mauro's Avatar
Re: Stains In Pool (Pictures Included)
Hello, I do service pools and see those stains very often cause by fertilizer. eventualy they will go away with time and good water balancing.
Good Luck
Mauro
Mauro is offline
Old 03-28-2008, 10:26 PM   #22
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Good Luck
Mauro
Yes the stains are starting to fade. Thanks for the info.
Sir Mixalot is offline
Old 06-29-2009, 07:57 PM   #23
honda03v6's Avatar
Trade: HVAC
Hi Sir MixAlot,
I just had this same issue happen to me yesterday. There are brown stains at the bottom of my pool and the around it. They look the exact same and I know it was due to the fertiler it actually fell out of my hand. How long did it take for it to be completely gone? Did you use anything that helped remove it faster? Which disappeared first inside the pool or around it? Thanks for any info.
honda03v6 is offline
Old 12-27-2009, 12:55 PM   #24
Mr Blaster
mrblaster's Avatar
Trade: Sandblasting Protective Finishes
Just did a pool job, and decking. Similiar spots showed up, turned out to be Muriatic Acid that was used to prep, and not rinsed off enough. Answer was to etch it again, and rinse off properly.
MrBlaster
mrblaster is offline
Old 05-02-2010, 08:14 PM   #25
sa1245's Avatar
Trade: C-53
These are definately from fertalizer. There is a product called a "Spot Eraser" that you can put on the end of your pole that will take these stains off the plaster without harm to the plaster.
sa1245 is offline
Old 05-03-2010, 09:50 PM   #26
Bruce
bf1024's Avatar
Trade: Tile and Marble also Swimming Pool
You can try to reverse ph (an in pool acid wash) however if you've never done it,you can damage the finish. As another poster pointed out, Jacks Magic sometimes works. Read and follow the instructions and have a stiff wire pool brush handy. (acid poured down a pvc pipe held over the stain can work if chlorine does not, but again dilute it 50-50 and be careful).If no luck, in Lauderdale I had dive tank and used stone which usually worked, especially if its only a surface stain. Duck poop WILL stain your pavers so its possible to have a dual problem, but I doubt that because of the palm food near that particular area.
bf1024 is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
Older pool Shamrock Pool Construction & Enclosures 19 01-07-2008 06:54 AM
i need russian architectural style house pictures ce824 General Discussion 14 12-28-2007 09:25 AM
Liner pool install ruskent Pool Construction & Enclosures 8 06-04-2007 05:47 PM
Gunite Pool builder /Nor-Cal...cool site D-pool dude Introductions 2 03-14-2006 07:36 AM
