Solar Pool Heater
Old 05-06-2007, 08:54 PM   #1
davidanbess's Avatar
Trade: Painting and Decorating
Solar Pool Heater
Hi will shortly be buying a solar pool heater (for above ground pool)
1/ which is the best to get
2/ is it possible to put it about 30 ft away from my pool on the ground
any feedback more than welcome.
Best regards D/B
davidanbess is offline
Old 05-06-2007, 09:00 PM   #2
dirt diggler's Avatar
Trade: contractor
Re: Solar Pool Heater
what is a bit ironic here is that the solar heating system will probably cost just as much - if not more than the above ground pool
dirt diggler is offline
Old 05-06-2007, 09:02 PM   #3
POOLMANinCT's Avatar
30 feet, serious loss of flow, replumb everyting w, 1.5 or 2".. otherwise system will be choked..
as fas as brand doesn't matter.....
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 05-07-2007, 08:17 AM   #4
Hi maybe I was not clear but it's the rubber type one with the water flowing through the elements which you just place in with full sun all day
Regards D/B
Old 05-07-2007, 02:25 PM   #5
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Run 1/2 inch tubing around the edge (of the pool) with a 3 way bypass valve connected after the filter. About 6 rolls or 600 ft should do. $100 tops.
Cdat is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 09:57 AM
Liner pool install ruskent Pool Construction & Enclosures 8 06-04-2007 05:47 PM
Gunite Pool builder /Nor-Cal...cool site D-pool dude Introductions 2 03-14-2006 07:36 AM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
