Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Pool Construction & Enclosures
Old 03-21-2007, 05:21 PM   #1
Hurley's Avatar
Trade: HVAC/swimming pools
Salt System on a Hot Tub
Need help with this one, and dammit it's a problem heater.
Got a custom inground small commercial size (6' by 12') spa run on a Jandy Auqalink RS 8 with an Aqua Pure salt system and a Raypak electric heater.
The Aqua Pure has been set to 5%, the lowest we can get it but the chlorine count has been off the charts from day one, resulting in 4 Raypak electric heater elements being eaten alive. For now the Aqua Pure has been dissabled in favour of chlorine tabs but the customer wants the salt system back up n' running asap.
Any thoughts at all would be helpful.
Hurley is offline   Reply With Quote
Old 03-21-2007, 05:25 PM   #2
how long has spa been on salt system, since construction? spa being shocked?
cyanaric acid being used? you said commercial size, is it a public/comm spa?
POOLMANinCT is offline   Reply With Quote
Old 03-21-2007, 05:36 PM   #3
Hurley's Avatar
The tub is big but for private use only. The spa is coming up on ten months old and on salt since construction. No other chemical treatment has been used past algacide and mineral out to combat hard water.
Old 03-21-2007, 05:39 PM   #4
im going to assume you have tested h20.
water must be very acidic, finish being damaged? once again cyanaric acid being used?
unit properly sized? what type of register is on this unit, i suspect the register/regulator to be faulty or damaged
Old 03-21-2007, 05:41 PM   #5
wait a minute
zero alk will chew heat exchanger in no time flat as will low ph...
what kind of hard water? minerals iron, magness etc) or calcium, what is the finish of tub palster or acrylic?
Old 03-21-2007, 05:54 PM   #6
Hurley's Avatar
It's an acrylic tub. The PH has been over 8.0 since day one due to the high chlorine count which has been over 10 ppm since day one. Surprisingly the alk has been reasonable at about 140. Our thoughts were that the disgustingly high chlorine was the cause. But how to lower it. the salt system is at minimum, and Jandy doesn't allow us to set it on an on/off schedual.
Old 03-21-2007, 05:58 PM   #7
i know jandy wont let you do so, thats was my first thought till i saw jandy.
cyanaric acid used at inital water break in?
im sure you have drained several times. sized equip properly, if water is torching equipment the reqisters/regs must be hammered by now
Old 03-21-2007, 06:19 PM   #8
Hurley's Avatar
To the best of my knowledge acid has never been used in this tub and oh yeah, been drained couple times.
Mind if I ask a question. Has anyone ever or do you think I could move the Aqua Link from the communication raceway to a relay so the operation could be timed. Thinking if the chlorine could be reduced from the corrosive level its at to something more managable we might get rid of the problem.
And you called it Ray. Planning on replacing every pump seal and o-ring long before they should be.
Old 03-21-2007, 07:22 PM   #9
i suspect even timed out gen unit is going to read/generate improperly. i think the units regulator has got to be shot.
cyanaric acid ie chlorine stabilizer, will lock up chlorine & not allow sublimation/gas off
not related to muri/hydro acid
Old 03-21-2007, 08:28 PM   #10
Trade: Swimming Pool & Excavating Contractor
hurley, is the spa indoors? Whats the gallonage, 17-1900 gals? I work with Clormatic/Jandy Aqua Pure units quite a bit...the last two days were spent in training with Jandy as a matter of fact.
We have had a lot of trouble with the Jandy units.
Sorry my error upon rereading my statement the chemical is not tsp but sodium thiosulphate.
This is what is used for neutralizing chlorine. It is actually one of the reagents in liquid test kits. aka taylor's 2005 for testing total alk.
Poolman is offline   Reply With Quote
Old 03-23-2007, 10:29 AM   #11
good one poolman, I didn't know TSP neutralizers chlorine. will it still nutralize chlorine if cyanaric acid is used as a cl stabilizer?
hurly what's u w this job?
Old 03-23-2007, 05:40 PM   #12
Hurley's Avatar
Not familar with trisodium phosphate but think I should find out about it.
The tub is outdoors and I make it 1400 gallons give or take. Can you elaborate on some of the troubles you mentioned.
Old 03-25-2007, 05:05 AM   #13
Chlorine gen. troubles we have encountered with clormatic/jandy units - Bad back boards, bad front boards, bad transformers, bad power cables to the cells, bad cells, bad sensors. On the bright side the case the boards are housed in, haven't fallen apart, nor have the tees the sensors come with broken . Seriously, we switched brands due to the recent accumulation of problems.
They were pretty good for a long time before they were bought out by Jandy.
Old 04-04-2007, 11:06 PM   #14
what's up hurley?? can we send a bill yet?
ray
apla tech system down under Drywall 4 08-09-2007 01:30 PM
Living Filter Septic System jmic Excavation & Site Work 18 07-20-2007 08:31 PM
Systems Development List Gordo Business 19 01-08-2007 07:28 PM
forced hot-water system daniem1 HVAC 1 03-02-2006 05:37 AM
Hydronic hot air system, help??? GMAN_2006 HVAC 1 02-27-2006 05:17 PM
