turning houses into homes
Trade: Wallcovering Installation
Pump/Filter Base ?
As some of you know from another thread in another forum, I am having my lined pool renovated.
Work will include new skimmer, returns, and lines. The filter/pump will be relocated into a soon to be installed pool house. I do not plan on having a slab poured for the pool house. I would like a framed floor (w/ PT ply flooring) sitting on blocks. I asked my pool guy what he wanted ready for a base for the pump/filter - I must have been unclear with my question because his answer was not relevant - or I misunderstood him. So I ask you guys, what would you want to put the pump/filter on. (sand filter this time) Can it go on the wood floor of the pool house or does it need a concrete pad ? If concrete, how thick ? If concrete, does the pad need to be relatively level with the pool house floor, or can it be a few inches lower? TIA -Bill |
Trade: Swimming Pools
Re: Pump/Filter Base ?
We use prefab lightweight concrete equipment pads. They come in standard sizes like 2' x 3' and 4' x 4'. We get them from the pool wholesale house, but I have seen the same type slabs used for HVAC equipment.
The elevation needs to be high enough that the pump won't flood. Never used wood but it would be a big hassle when you had to replace it. |
Trade: contractor
i don't use pre fabs - i hate em
i might have an idea for you da arch - you're basicallyy just having a block foundation and the pool house framed on top of that - right? so you'd have a crawl space?? |
A pad is the only way to go. Have you done any weight calc's on a sand filter full of water? The last one that I did a pad for was 3600#'s. It WAS a big pool and we live on sand.
Dirt Diggler,
Yes and no. Blocks - yes. Foundation - no. It's just a small pool house - actually a shed - 8 x 10 is the only size we can fit (and afford). Blocks will be used to support and level corners. No crawl space, unless you're a chipmunk. The floor will be approx 10" above grade. Teetorbilt, ALMOST 2 TONS !?!?!?!. WOW, I had no idea. It's a 20,000 gal pool. Filter will be a 20 inch Hayward sand. Pump is not heavy - 30-50 lbs (?). The old DE filter was what? 200 - 300lbs WITH water??? But that's why I asked you pool pros. You know the business. I'm just a paperhanger. I know walls - you know pools and equip. |
20" tank - 250 sandlbs + 40gal (@ 8 lbs. per gal 320). 570lbs
4x8x4" pad plenty to hold that set up & room to retro a heater in the future. ask you installer to bury a "dumby" set of lines & punch new 1408s in panels. so when a line breaks (& one will) you just have to cut the liner at faceplate & tie into the pipe stub @ filter area, or you can rip up the new deck for a repair if you prefer. any ?s ray
......Less with the jaw & More with the paw..... Last edited by POOLMANinCT; 10-01-2007 at 09:21 PM. |
| shower base | C.C.R. | Ceramic & Stone Tile | 11 | 07-30-2007 10:56 AM |
| Sub Base for pavers | mcgyverdc | Landscaping | 20 | 01-14-2007 02:48 PM |
| Saw to cut Base Board vertical | 415moto | Tools & Equipment | 28 | 12-18-2006 08:08 PM |
| Oil base or water base poly? | jhf469 | Flooring | 4 | 11-24-2006 11:36 PM |
| vendors for oil base. | mdshunk | Painting & Finish Work | 5 | 11-11-2006 08:34 PM |
