Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Pool Construction & Enclosures
Old 01-13-2008, 09:36 PM   #1
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
Pool light
Burnt out pool light
Is this something simple to do or is it a call someone sort of thing?
I have this issue with water and electricity, oh and my well being
Chris
Chris Johnson is offline   Reply With Quote
Old 01-13-2008, 09:39 PM   #2
Fentoozler
Celtic's Avatar
Electricity is not something to be feared...it is to be respected.
If you fear it, hire someone who respects it.
If you have fear and respect confused - hire someone.
Celtic is offline   Reply With Quote
Old 01-15-2008, 06:23 AM   #3
Trade: Swimming Pool & Excavating Contractor
What type of pool?
If it's an above ground...install an inground.
If it's an inground do like dirt suggested in the other thread..."drain it" or just remove the screw holding it in the wall pull up to the coping and change the bulb & gasket.
Good luck.
Scott
Scott
Is this going to be expensive?
It's all relative.
Poolman is offline   Reply With Quote
Old 01-15-2008, 11:43 AM   #4
Bunny by Malco - NY
Don't fear - I respect electricity
Pools below ground, I have never seen the inner workings of the lights and was not sure how the fixture was sealed to be protected from water.
It's cold hear right now, daytime high of 65F, I'll get brave one of these days and climb in and change it out, just wasn't sure how it was connected/sealed.
Chris
Old 01-15-2008, 12:32 PM   #5
Fentoozler
Celtic's Avatar
Gaskets and/or "O" rings and set screws/threaded lense component would be my guess...
Old 01-17-2008, 11:18 AM   #6
1. concrete or liner pool,
if liner do not remove gasket plate!!!!!! not shown in diagram.
2. I always just replace the whole assembly from jbox to pool. note, if a big AB booger is in conduit, you will have to chip it out to remove assembly.
(i opt to drill a hole in an expansion plug and pull it down cord to seal conduit. assuming conduit is not in great shape.)
- if you just opt to replace bulb, reassemble the unit & sink it in pool & watch for air bubble, indicative of gasket leaks.
- do not tuurn light on outside of water, they are water cooled.
ray
......Less with the jaw & More with the paw.....
POOLMANinCT is offline   Reply With Quote
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 08:16 PM
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
Older pool Shamrock Pool Construction & Enclosures 19 01-07-2008 06:54 AM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
Inground pool light circuit louis bugaj Electrical 28 11-07-2006 11:19 PM
