Need Pool Help Bad
Old 11-16-2009, 01:23 AM   #1
robin303's Avatar
Trade: Remodel and new construction Austin, TX
Need Pool Help Bad
The lady that I have been working for on and off for 10 years took off to visit her daughter because the old man is about to die I hate to say. She wants me to start taking care of a 23,000 gal pool. When I saw it was really green. Anyway to be honest I don’t know anything about pools but I did start pumping the water out but it stopped at the skimmer or where the filter is which is may a foot down or so. OK I figure this a standard setup and my question is can I pump the water out with the existing pool equipment or do I need to just rent a gas powered pump. Any help would be appreciated.
Thanks
Robin303 Army Air Slideshow
robin303 is offline
Old 11-16-2009, 10:23 PM   #2
Sean
SLSTech's Avatar
Re: Need Pool Help Bad
Go get the water tested - they will tell you what chemicals you need to add to clear it up - there are very few reasons to fully pump out a pool
You may also have to replace the filter or sand after it is fully cleaned out, either write down the info or snap a few pics. They also have test strips to help keep the chemicals at the right levels
If you need to fully pump it out - an electric pump works fine - the regular pool equipment is not meant to do this
Check with the local city officials because some will nail you big time for letting it run in the streets or into the storm water system
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
robin303 (11-17-2009)
Old 05-03-2010, 10:16 PM   #3
Bruce
bf1024's Avatar
Trade: Tile and Marble also Swimming Pool
And by all means dont run the pump down with the skimmer valve open, if you ran that pump for any length of time after the water dropped to the bottom of the skimmer, you may have already damaged the pump....it gets hot,ruins the shaft seal, then a $7 shaft seal allows chlorinated water (when you get it blue) to run past the shaft seal and get into the front bearings of the pump, which rusts them and in a little while you get a squealing pump and eventually it will simply seize up.
bf1024 is offline
Pool Demolition tgeb Pool Construction & Enclosures 4 05-02-2009 11:37 AM
Dehumidification for Indoor Pool Chrishel Pool Construction & Enclosures 3 04-30-2009 02:37 AM
