Little Question On Changing Pool Coping
Old 03-14-2007, 08:28 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
I am looking at a nice little job on friday. People have a concrete pool with cantiliver concrete coping. The coping is poured with the deck. The want the coping replaced with bullnose and new tile added.
So no big deal right? I am guessing i would take a demo saw and make a cut all the way around the pool with the saw and remove the 12in (or whatever it works out to be). I am guessing i can use my bosch hammer drill with chisel if i need help removing the concrete.
Then i carefully remove the tile, which half are falling off. The pool was retiled a few years ago, but was done poorly they say.
So what can go wrong on this job? I figure i'd ask before i even go look at it?
ruskent is offline
Old 03-14-2007, 08:31 PM   #2
POOLMANinCT's Avatar
Re: Little Question On Changing Pool Coping
matt pix please...
when i here falling tile i think of other problems
POOLMANinCT is offline
Old 03-14-2007, 08:38 PM   #3
thinking what im thinking dirt??
cantilever tied to the beam??????
Old 03-14-2007, 08:41 PM   #4
dirt diggler's Avatar
Trade: contractor
Ray's (good and so valid) point aside ...
what type of coping do they want?
what will you use to adhere it to the bond beam?
how wide is your bond beam?
how do you know how wide your bond beam is?
what is your plan for removing the concrete without damaging the (potentially damaging) bond beam?
how will you clean off the bond beam once concrete is demoed?
what effects of demo-ing the concrete will be seen on the beam?
what is your plan for the expansion joint between the eventual coping and deck?
what is your plan for retiling?
what type of tile is it?
does that type of tile exist?
if draining - will you provide water?
if not draining - who will clean pool (cuz it WILL be FILTHY)
what is your plan for draining the pool (you are draining it, correct?)
if you do drain the pool ... how will you protect the plaster?
if you do not drain the pool ... how will you protect the plaster
dirt diggler is offline
Old 03-14-2007, 08:47 PM   #5
matt
how did you find this job & are you ready for this kind of work?
Old 03-14-2007, 09:06 PM   #6
ruskent's Avatar
Trade: Outdoor D/B
I really do not know what the situation is here. I will take pictures and post them after i look at it on friday.
First they said tile was falling into the pool, then they said it was concrete from the cantiliver decking. When i see it i will let you know.
This is a lead form my first home show. These people have a shore house (by where the show was) and have a house about 45 minutes from me where this pool is.
I really think this is something i could handle if i knew exactly how to handle it without screwing something up. Mortaring bullnose is nothing new to me, neither is tile. I tiled showers, walls and floors but never a pool.
BTW looks like i may be subing out a entire gunite pool as part of a huge landscape job. I am going to need some tips on that as i progress with the design.
ruskent is offline
Old 03-14-2007, 09:08 PM   #7
then you have to pay sorry charlie
Old 03-14-2007, 09:38 PM   #8
Trade: contractor
lol ... 40K ...
Matt - that's great that you got one
i gotta ask ya ... how'd you do it ??
the HOs are fine with the fact that you've never built one before??
(or have you ?? or worked on one??)
Old 03-14-2007, 09:53 PM   #9
ruskent's Avatar
Trade: Outdoor D/B
I don't have it yet. I'll pm you the details later.
ruskent is offline
Old 03-21-2007, 10:38 PM   #10
matt what's up w/ the coping job? have you checked it out or is there a foot of snow on it?
Old 03-22-2007, 08:52 AM   #11
ruskent's Avatar
Trade: Outdoor D/B
I am waiting on the snow to melt to go out and look at it.
ruskent is offline
Old 03-22-2007, 09:53 AM   #12
Trade: contractor
how high is the water level now ...
and
how long ago did tiles just start falling off??
how old is the pool
what's surrounding grade like??
Question for the Pool guys/Plasterers/masons Tscarborough Pool Construction & Enclosures 13 08-15-2007 06:17 AM
Pool Coping Bodey Built Pool Construction & Enclosures 1 06-12-2007 08:34 PM
Question about pool wall support/loads intruderdriver Pool Construction & Enclosures 16 05-24-2007 10:08 PM
Where to buy bullnose coping? noface Pool Construction & Enclosures 2 05-11-2007 01:24 AM
