Inground Pool, How Do You Work On Sides?
Old 03-01-2009, 07:17 PM   #1
Jrmull's Avatar
Trade: homeowner pool owner
Sorry for the dumb question, but when working on the lights in the deep end of an inground pool, how do you get up the sides that are 8 feet from the bottom?
The bottom is soft vermiculite cement. The liner is being replaced so I need to work at a 45 degree angle and I don't want to mark up or dig into the bottom.
I saw Tom Cruise do a jewelry/bank job suspending himself from the ceiling. Maybe hang upside-down with a rope from the top. Maybe lay a ladder on the angle wall and a flat plywood on the base.
What's the trick? The ladder seems like I will mess up the wall sides.
Regards,
John
Jrmull is offline
Old 03-02-2009, 10:09 AM   #2
Shoreline58's Avatar
Re: Inground Pool, How Do You Work On Sides?
The plywood's sharp edges may dig in and cause damage. Try a CLEAN drop clothe or moving blanket with a sheet of 2" rigid foam insulation on top. Good luck.
Shoreline58 is offline
Old 03-10-2009, 11:58 AM   #3
Shawn the Poolman
ShawnP's Avatar
Trade: Swimming Pool Construction, Renovation, Service
Anchor point, repelling harness and patience. It sound goofy but it works if you have a delicate situation.
ShawnP
ShawnP is offline
Old 03-10-2009, 09:26 PM   #4
j_builder's Avatar
Trade: Specializing in residential remodeling
Regards,
John
Simple answer for replacing the light(s)... snorkel and mask.
j_builder is offline
Old 03-11-2009, 10:59 AM   #5
Shawn the Poolman
ShawnP's Avatar
If the pool light was installed properly you should be able to hang over the edge (Have someone hold feet if tall walls for safety) remove the light and there should be plenty of line to bring fixture to deck to replace bulb or hook new light line to once cut. Then just pull new light cord through.
Hope this helps
Shawn
ShawnP is offline
Old 06-11-2009, 04:20 PM   #6
POOLMANinCT's Avatar
Might be late to the party... But nicely "cooked" verm is pretty tough stuff...
Don't sweat it...
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 06-11-2009, 04:40 PM   #7
mmike032's Avatar
Trade: trim carpentry
have David Blaine replace it for you
mmike032 is offline
Old 06-11-2009, 04:45 PM   #8
Administrator
Nathan's Avatar
Trade: Admin
Please post your question over at www.DIYChatroom.com. This site is for pros only.
Thanks!
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
taking a crack at my own concrete work J-Peffer Masonry 9 10-25-2010 06:16 PM
State work and requirements J-Peffer Business 2 01-26-2009 01:23 PM
Looking for roofers who want to WORK bew102 Help Wanted or Looking For Work 5 12-18-2008 10:47 PM
Anybody thats looking for work in texas.... SteraClean Help Wanted or Looking For Work 1 11-22-2008 08:44 PM
Hiring office work/paper work people? J-Peffer Roofing 3 06-22-2008 11:22 AM
