Trade: Home improvements
In Ground Pool Liner
I'm hoping someone can help with this. Here goes, We have an inground about 12 x 40. We had a new liner installed professionaly about 6 years ago. Hear is the problem or problems.....I've noticed over the last 2 years several air pockets under the liner in the shallow end. What could be causing this and how can I remedy the problem. Also, last year by the end of the season the liner was pulling away from the side of the pool wall. There were 2 spots about 7 - 10 inches long. When I uncovered the pool last night there were 8 spots where the lining is slipping out of the groove and each of these is about a foot long. Is there a way to fix this and prevent it from pulling in the future? Is this a common problem, was the liner installed properly etc? By the way the person that installed the liner sold his business and is now partnered with a larger company. I cant even get him to come look at the pool. Any help/advice would be appreciated.
Trade: contractor
Re: In Ground Pool Liner
Ray's your man for this one ... i believe this area is his forte
has the water level dropped??? offhand - i'd say there's a tear and those "pockets" are not air, but water did they use a shop vac when they were installing liner/filling with water??? first i'd check for any tears/leaking |
The water level has not dropped. I have inspected the lining for tears, rips etc and can find none. I was not present for the intall so I cannot say if they used a vac or not. We actually had no problems other than the lining pulling away before last year. The guy that installed the lining came back the year after and fixed an area where the lining had pulled away from the wall. Perhaps it is h2o and it is filtering behind the lining where it is pulled away from the wall.
Trade: contractor
might wanna post a pic too
1.your not properly caring for your pool. allowing h20 to rise & floating bead out of track
2. you have drainage problems, & allowing h20 to pool between liner & panel your liner is 6 yrs old this is not an installation issue. click
......Less with the jaw & More with the paw..... |
http://s185.photobucket.com/albums/x...elsonfloat.jpg
liner I installed 5 yrs ago, floated 2 weeks ago... drained reset & bead locked monday.... 45min $1000 a shop vac dirt?? go tie some steel buddy!!!!
mgm.
ppost pic of your decking, "liner sag", pool etc. is there foam behind your liner? any wrinkles/creases on floor? what type of winter cover do you use? weeping willow trees in yard, sump pumpp in basement.... procedure use to winterize pool.... pardon me hanging up on you "click", we are just a bit cranky in the "pool basement" anyway answer all my questions & post pics, ill coach you through it. ray
yeah no problem.... glad we can help......
Trade: contractor
shoulda charged for consultation
why bother.....
perhaps nathan can set up a password to get into our dungeon.....
| Ventilation problem with an indoor pool | frostbitten1 | Roofing | 10 | 05-27-2009 09:16 PM |
| Liner pool install | ruskent | Pool Construction & Enclosures | 8 | 06-04-2007 05:47 PM |
| Replacing inground pool liner | cprojects | Pool Construction & Enclosures | 1 | 05-03-2007 12:23 AM |
| liner integrity tip (at sales calls) | dirt diggler | Pool Construction & Enclosures | 1 | 03-06-2007 01:27 PM |
