Cracked Joints Between Coping
Old 03-11-2009, 01:25 PM   #1
72chevy4x4's Avatar
what is the pro's recommendation for repairing cracked joints between coping-currently it appears to be mortar and the cracks range from hairline to 1/4".
I spoke w/ Deck-o-seal and they recommended 787-their deck-o-seal product but didn't get clarification if that was acceptable between coping or geared more for the expansion joint between the coping and deck.
72chevy4x4 is offline
Old 03-11-2009, 09:07 PM   #2
j_builder's Avatar
Trade: Specializing in residential remodeling
Re: Cracked Joints Between Coping
72chevy4x4-Any pic's?
Taking into consideration that your talking about safety grip standard coping. To really do a "professional" job I'd just remove the motar between the coping, deckoseal isn't going to get the look of the motar and it's going to look like a hack job imo.
You might also want let the pool owner know that also.
j_builder is offline
Old 03-12-2009, 07:43 PM   #3
Shawn the Poolman
ShawnP's Avatar
Trade: Swimming Pool Construction, Renovation, Service
I'll second that and add this. Make sure the coping is not loose.If it is safety coping and loose; remove it, buff bottom with mini grinder ect and re-attach with straight white cement that is fairly wet; it will not come loose again.
ShawnP
Aquatic Playground International, Inc
Shawn@aquaticplayground.net
ShawnP is offline
Azek butt joints holding up? LeonardDB Finish Carpentry 39 11-28-2009 08:30 PM
Gutter joints leaking JTW Roofing 4 02-13-2009 07:45 PM
Powercope coping saw Trim40 Tools & Equipment 2 02-06-2009 09:36 AM
Control/Movement joints Cache Flooring 6 11-02-2008 01:10 AM
Pool Coping Bodey Built Pool Construction & Enclosures 1 06-12-2007 08:34 PM
