Copper Niche Is Shot
hi guys
i have a copper niche thats is shot, vinyl pool i was thinking of covering niche w/ sheet metal, punching a hole fo a sp1480 , then vinyl & hanging a nichless aqualoom brand lamp.. whil using the existing j box & conduit? my only issue may be having a transformer installed or removed??? watch think? i just dont want to break deck .. id eliminate it before thaT. ray |
Trade: contractor
Re: Copper Niche Is Shot
gotta meeting - will review upon review and completion of dinner
interesting |
well mdshunk had nothing of merit to add so from the sparky side thats encouraging
Trade: HVAC/swimming pools
If I'm guessing right the copper niche is a starite light. These are 120/240 so sould be no transformer needed and the deck box ain't got room to accomadate one.
You got my attention with "nichless light". Can you give me any more info bout it. |
Re: Copper Niche Is Shot |
NICE. My guess would be to go for the 250 watt lamp at 120 volts to eliminate the need for a transformer (but I'd still throw a meter on the existing feed to make sure it ain't 240 volts). The customer will get more light with out costing more power and an easier installation means more money in your pocket.
& no jackhammer for me, as long as conduit is in tact
Trade: contractor
one pita would be getting to the old conduit
(to cut from the existing niche) although ... you could use one of those little saws that cut on the INSIDE of piping (ive seen em on TV before |
nah,
I should be able to cut old lamp cord. tie new cord to it & pull it right up to my box... |
Trade: contractor
oh wait - you're leaving the old niche then??
leaving the old niche and just putting a scrap of steel panel over it and THEN punching the holes for the new niche-less??? and then fishing the new cord with the existing?? (NOT splicing - but just fishing??) one question --- did this start out as a leak detection job?? |
yup
now it is a replumb liner safety cover & system who's your daddy?!?!? back to the point... this light is going to be easy... oh I just thought about bonding... where mds when ya need him.... ill run it buy my e1 in the am |
Trade: contractor
NICE!!!!
welp ... im up way too late |
Trade: Swimming Pool & Excavating Contractor
Does the light need bonding?
I wouldn't think so because you don't normally bond the light itself...just the niche. I am assuming the old niche is already bonded from before on the outside. Although the inspectors have been requiring a second bond wire pulled through with the light cord in the conduit and attached to a lug on the inside of the light niche. Any one else have to do that? Let me know. |
nope its good to go...
pretty sneaky trick, eh pool? good 600$ upsell
......Less with the jaw & More with the paw..... |
I have no idea what a niche-less pool light is, as I've never seen one. Thus, my resistance to offer any input on this. The electricians that do pools in my area are normally employees of the pool contractor. I do maybe 2-3 pools a year, so they are far from something I'm competent on. Anything out of the ordinary, I have to look it up. Niche-less... I don't even know where to begin investigating that.
basically it is a lamp in a plastic housing that is bracketed onto the pool
wall, bracket is also plastic
#17 | |
Re: Copper Niche Is ShotQuote:
Or, does it come in the back of the fixture, through a conduit, similar to a wet niche fixture?
#18 |
the bracket is fixed to the wall through a plumbing bulkhead fitting,,
in this particular renovation the standard niche will be covered w/ sheet metal and punche to accept the bulkhead & brackets
#19 |
sorry I didn't answer the ? md..
wire comes from deck/jbox conduit through the above posted bulhead...
#20 |
Is the conduit required to be continuous from the deck box to the no-niche fixture bulkhead fitting, per the fixture manufacturer's instructions? If so, I'm puzzled how you'll extend it from the back of the old wet niche to the bulkhead fitting?
| pex vs. copper | Mr. D | Plumbing | 68 | 05-16-2008 11:46 PM |
| Aluminum to copper lug | Mike Finley | Electrical | 21 | 06-03-2007 12:31 AM |
| Cement Contact with Copper Pipe | Capt2 | Plumbing | 11 | 04-17-2007 09:05 PM |
| Painting new gal. gutters copper | DeanV | Painting & Finish Work | 0 | 06-22-2006 09:39 PM |
| Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 08:51 AM |
