Concrete Damage
Old 07-12-2008, 11:58 PM   #1
blockhd9's Avatar
Trade: masonry
Concrete Damage
ok pool guys second year pool owner please forgive my ignorance! thanks in advance ! pool installed in 1971,free form beauty pool(gunite,plaster) the sidewalk around the pool has lifted slightly(inch or so) therefore making gap in spots around pool. is this bad should i replace side walk or chaulk the gap? is the sidewalk called the coping? can i simply replace tile around top edge of pool as they are wearing out?. also have in wall strainer wear sidewalk has lifted can this be busted out and repaired? i am sure i have more questions but i will wait for your replies. o one more what would be directly under the sidewalk? i mean generally speaking i am sure we can not be certain. once again thank you all!
blockhd9 is offline
Old 07-16-2008, 11:39 PM   #2
CaliDesigns's Avatar
Re: Concrete Damage
not enough info. pics would be helpful, where are you located,
CaliDesigns is offline
Old 12-06-2008, 08:54 PM   #3
Darren CA's Avatar
Re: Concrete Damage
Sounds lie bond beam seperation, but you are right... need pics
Darren CA is offline
Old 12-09-2008, 12:17 PM   #4
POOLMANinCT's Avatar
Re: Concrete Damage
there are a few beam threads here, noisy and expensive
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 12-09-2008, 05:59 PM   #5
j_builder's Avatar
Trade: Specializing in residential remodeling
Re: Concrete Damage
Originally Posted by blockhd9 View Post
ok pool guys second year pool owner please forgive my ignorance! thanks in advance ! pool installed in 1971,free form beauty pool(gunite,plaster) the sidewalk around the pool has lifted slightly(inch or so) therefore making gap in spots around pool. is this bad should i replace side walk or chaulk the gap? None of the above-hire a pool professional.
is the sidewalk called the coping? No, it's call decking. can i simply replace tile around top edge of pool as they are wearing out?.No again-the gunite/shotgrete/blocks are separating from the pool structure. also have in wall strainer (pool skimmer?) wear sidewalk has lifted can this be busted out and repaired? Jackhammer out and proceed with caution. i am sure i have more questions but i will wait for your replies. o one more what would be directly under the sidewalk? Dirt,plumbing,gas line(s),electrical line(s) possibly and of course more dirt. i mean generally speaking i am sure we can not be certain. once again thank you all!
More details with pic's would do this thread wonders...
This is what the 'bond beam' looks like around the swimming pool.
j_builder is offline
The Following User Says Thank You to j_builder For This Useful Post:
CanCritter (02-15-2010)
Old 03-10-2009, 12:19 PM   #6
Shawn the Poolman
ShawnP's Avatar
Trade: Swimming Pool Construction, Renovation, Service
Re: Concrete Damage
Yes anything can be repaired with correct knowledge (Info) when it comes to pools.But, If you do it wrong it will cost you big.
ShawnP is offline
Old 03-10-2009, 09:32 PM   #7
j_builder's Avatar
Re: Concrete Damage
If you don't follow up on questions...Jeeezzz some people need to read a book...including me every now and then.
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
Concrete countertop acid stain problem AHS Concrete & Paving 12 05-09-2008 02:14 PM
