Black Bottom?
Old 08-25-2009, 12:04 AM   #1
1 man show.
zipicus's Avatar
Trade: Finish Carpentry
Black Bottom?
So do you think if I get a Pebble Tech Black Pearl bottom it will keep a 17'x14' pool in NorCal w/direct sun in the early spring warm??
1 man show.
zipicus is offline
Old 08-25-2009, 09:17 AM   #2
Sean
SLSTech's Avatar
Re: Black Bottom?
Uh, maybe by .1 degrees
You can use a liner designed to trap heat for a little warmth, or you will have to go with a solar or regular heating system to actually bring the temp up
Whatever the average low temp (between 60 to 90) was for the past 3 nights is generally what the pool temperature will be.
SLSTech is offline
Old 08-25-2009, 03:56 PM   #3
1 man show.
zipicus's Avatar
Re: Black Bottom?
Wow, a black bottom makes that little of difference?? So then any idea how much it would cost for a solar install to heat a pool this size??
1 man show.
zipicus is offline
Old 08-25-2009, 05:54 PM   #4
Sean
SLSTech's Avatar
Re: Black Bottom?
About tree-fiddy, sorry but it has been years since I even looked into them in AZ & I couldn't even hazard a half way decent guesstimate now
You might want to start here http://www.builditsolar.com/Projects...ol_heating.htm & go from there
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
zipicus (09-20-2009)
Old 05-03-2010, 11:19 PM   #5
Bruce
bf1024's Avatar
Trade: Tile and Marble also Swimming Pool
Re: Black Bottom?
It will take about 238 square ft of solar panels to do the job efficiently ( 1 sq ft panel per sq ft pool surface area). Suggest you call around. Most of the time your pump will have to be upgraded to handle the increased head pressure to get it up to the roof, thru panels and back. Check into that as well.
bf1024 is offline
black counter refinish Traditions2 Painting & Finish Work 3 07-29-2009 09:17 PM
Wood 'footing' on ground at bottom of steps up to deck ??? akm Decks & Fencing 7 07-05-2009 02:56 PM
I need a to pour 1/4 yard of black concrete... ruskent Masonry 9 05-25-2009 12:50 PM
Black marks left by inside corner applicator AARC Drywall Drywall 5 10-04-2008 09:41 AM
