Standard Setback Of Sink Hole
Old 01-14-2010, 12:21 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 2,558
I am working on a cabinet and the client wants a tilt out for the sink front. Everything in this kitchen is tight. the cabinet (top) opening is 22 3/4 x 28 7/8 and we are putting a 18 x 28 (26 x 26 ID) undermount sink that is 9" deep.
What I'd like to know is what is the standard setback for the hole from the front of the countertop for an undermount sink. And how far back can I push it before it gets uncomfortable to wash dishes in the sink.
Thanks.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-14-2010, 01:01 PM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Standard Setback Of Sink Hole
It's usually between 3-1/2" - 4" setback.
Stainless?
What make and model and I'll see if I have it in my CAD library. I have quite a few.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 01-14-2010, 01:28 PM   #3
genecarp's Avatar
Rewards Points: 2,000
Leo, wnen tolerances are tight it also helps to know what the backsplash behind the faucet will be as well as the faucet type escuchen size etc....GMOD
genecarp is offline
Old 01-14-2010, 01:31 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
I believe it really depends on the make/model. Most sinks I deal with are 18"-20" front to back. You obviously cannot center each sink because of the counter overhang but I think you'd be pretty safe assuming at least 3" back.
If it's an equal-double, I'd try to center in on the counter. If it's a 1-3/4, I'd try to center it on the small side.
A 4" setback on a 20" sink is putting it almost into the backsplash.
Angus
angus242 is offline
Old 01-14-2010, 02:47 PM   #5
LRG WoodCrafting
Leo G's Avatar
Flange to flange it is 18" deep, the sink itself is 16" deep, I assume the countertop backsplash will be the same as the counter, they could easily make it out of 3/4" as they could from the 3 cm (countertop thickness).
Stainless steel, yes. Single basin.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-14-2010, 03:32 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,098
I can't help you as I know nothing about doing dishes.
All paper plates and sporks at my house.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-14-2010, 03:47 PM   #7
LRG WoodCrafting
Leo G's Avatar
Just glad you could participate with the topic. Thanks.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-14-2010, 03:57 PM   #8
I like Green things
Don't mention it!
Warner Mill Works
Facebook
YouTube
Old 01-14-2010, 04:08 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Leo,
I think you need to get specs from either the designer or counter top folks. What will the over hang be? Are you sure about the 3/4" backsplash? I have seen guys do a full 3cm backsplash.
If you go typical (not saying standard) 25" counter top with 3/4" backsplash and a 16" visible sink, that gives you 4 1/8" spacing on both sides of the side (front/back).
Now if there's going to be a single hole, single level faucet, you need to account for the handle swinging towards the backsplash. I'd assume almost 2 1/2" swing backwards. In that case, you may want to move the sink forward to accommodate the faucet handle.
Honestly, if the sink and faucet are already picked out, the counter guys should have these answers.
Angus
angus242 is offline
Old 01-14-2010, 04:24 PM   #10
genecarp's Avatar
Originally Posted by angus242 View Post
Leo,
What he said, additionally often we have had requests for those tilt out drawer faces, and often, the numbers do not allow enough room. GMOD
genecarp is offline
Old 01-14-2010, 05:14 PM   #11
LRG WoodCrafting
Leo G's Avatar
I haven't done a tilt out is a long time. Usually my sink cab is 36" and there is room on the sides for the hardware to clear the sink. This sink is going to fill the width of the cabinet. I had to make the lazy sue cabinet 1" short on the sink side so I could center it under the window. If the window was 1 to 2" more to the right I probably wouldn't be having this issue. She wants the biggest sink she can get in this cabinet and plans on using the dishwasher....
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-17-2010, 03:44 PM   #12
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,130
I hope a little farther then this one>
Snobnd is online now
Old 01-17-2010, 07:54 PM   #13
Project Superintendent
mudpad's Avatar
Ha Ha! that's the first thing I thought about when I read the title to this thread too.
mudpad is offline
Old 01-18-2010, 07:56 PM   #14
Snobnd's Avatar
The one in the Picture was down the street from where I was working back in ...........80's in winterpark Fla. I went down to see it happen - omg- cars, trucks, boats were falling from the garage in the middle top.
I think it got 3 -4 house's and then the pool at the bottom.
not a good day for a few people
New OSHA standard OsNap Health & Safety 8 01-08-2010 09:19 PM
Good quality tile hole saws and lockboy hole cutter? BCConstruction Tiling 10 08-21-2009 10:29 PM
Replacing a Porcelain Sink jerome8283 Plumbing 2 06-06-2009 10:10 PM
Need help! Hole for sink cut too big! sage Plumbing 32 02-05-2009 03:10 PM
waterjet cut sink hole webcruiser8 Kitchens & Baths 3 12-09-2007 10:41 PM
