Shower Glass Set Into Soapstone - Kitchens & Baths - Contractor Talk
Old 01-25-2018, 09:31 AM   #1
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 768
I'm thinking of routing dados into my soapstone bench and curb slabs to accept my shower glass.
Anyone know of a reason why I shouldn't do this?
I figure that as long as I make the channels a bit wider for expansion differentials and silicone installation, and place clear plastic damper shims under the edge of the glass to prevent direct contact with the stone....
I should be fine.....
Right?
Thanks in advance for any helpful advice,
Jonathan
BlueRidgeGreen is online now
Old 01-25-2018, 09:33 AM   #2
Trade: Craftsman
Rewards Points: 768
Re: Shower Glass Set Into Soapstone
I just thought of one reason.....
Silicone removal and re-application down the road might be a bit of a PITA.
Hmmmmmmm.......??
Old 01-25-2018, 09:37 AM   #3
VinylHanger's Avatar
Rewards Points: 8,026
I wouldn't have a problem installing into that system. Are you going to dado the wall tile as Well?
My concern with a no channel install is I don't trust the silicone to hold in the long term. I know it is done, but I won't do them.
VinylHanger is online now
Old 01-25-2018, 09:40 AM   #4
Hmmmmmmm.......??
That may be a downside for sure. However, if the silicone is only applied where it is exposed, it won't be trapped where you couldn't get to it.
Old 01-25-2018, 09:43 AM   #5
Trade: Craftsman
Rewards Points: 768
The wall tile is easy.
I'll just leave a glass-sized joint.
I hate clips.
Because I hate relying on silicone.
I prefer channels.
This would be like a stone channel.......????
I really wish all my glass could defy gravity without any metal.....hence my desire to eliminate the metal channels on the curbs.
Old 01-25-2018, 07:00 PM   #6
Trade: Craftsman
Rewards Points: 768
Alright....
Since I have not once been called a complete idiot in this thread (as of yet),
I will consider that as my tacit approval to forge ahead.
I appreciate your participation,
Jonathan
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Xtrememtnbiker (01-25-2018)
Old 01-25-2018, 07:47 PM   #7
tjbnwi's Avatar
Rewards Points: 4,006
Use the Schluter set in channels, problem solved.
Silicone may discolor the stone.
tjbnwi is online now
BlueRidgeGreen (01-25-2018)
Old 01-26-2018, 07:14 PM   #8
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
what if your stone was "curbed" so that from outside you cant see clips???
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Am I crazy? Shower door shesbros General Discussion 22 08-31-2017 05:12 AM
Shower glass options gbruzze1 Kitchens & Baths 4 03-06-2017 01:58 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 04:38 AM
Exposed shower system onto glass wall Maplehead Plumbing 1 06-15-2010 05:39 PM
Shower Glass atipton Remodeling 3 10-17-2007 07:50 PM
