Shower Door Install Into Fiberglass Base Question.
Old 02-17-2013, 09:49 PM   #1
VinylHanger's Avatar
Rewards Points: 7,264
I have installed a lot of shower doors. I usually try and stay away from DIY installs, but this was a referral from a plumber buddy who sends me a good deal of work.
My problem is I have to install Prima hinges into a DIY style fiberglass shower pan. There is no solid support to grab the screws. My supplier thinks it will work, but with 1/8 of an inch to screw into, I'm not sure. I've already made three trips to try and get tis installed. Not my or my customers fault, but it needs to work this time. If I had known how this pan was built I would have tried to sell them a nice heavy slider.
Anyway, my only options seem to be an insert of some kind, which I'm not sure will be strong enough in the long run. My other thought is fill the immediate area with epoxy and then run screws in while wet or let it set and then drill into the epoxy.
Any thoughts, or ideas on what epoxy would work? Like I said, I know it isn't a perfect situation, but I have to make it work.
VinylHanger is online now
Old 02-17-2013, 09:54 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 764
Re: Shower Door Install Into Fiberglass Base Question.
The insert might be your only choice. Usually the curb on those bases are hollow and you would dump epoxy all day long before it would work.,Try a hollow wall anchor with epoxy. Mask the area and put some epoxy under the base of the Prima also.
overanalyze is offline
VinylHanger (02-17-2013)
Old 02-17-2013, 10:03 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Why not remove wall material behind shower walls and install a piece of a tree to screw into..
ohiohomedoctor is offline
Old 02-17-2013, 10:07 PM   #4
The prima is a pivot hinge that attaches to the header and the base. I couldn't use a wall hinge because of the tile work. Let's just say there was a bit of non flatness.
The Following User Says Thank You to VinylHanger For This Useful Post:
overanalyze (02-17-2013)
Old 02-17-2013, 10:13 PM   #5
Always Learning
Rewards Points: 764
...could you do that to the floor below the curb from below?
ohiohomedoctor (02-17-2013)
Old 02-17-2013, 11:19 PM   #6
Finished basement. No way am I gonna tear into that.
Old 02-17-2013, 11:25 PM   #7
Pivot hinges dont handle much oblique torch. Usually just downward force. Drill a whole and fill that bad boy with whatever you have in your garage. Spray foam would likely be enough and you could even put your screws in lime you talked about. If you have enough coverage on this hinge maybe consider a toggle anchor which could be tightened a little after the foam dries.
I would get window and door though to make sure it doesn't pop the base off the floor..
Old 02-17-2013, 11:27 PM   #8
I am still confused how you got stuck cleaning up a mess at your expense. Id just throw the hack under the bus and propose fixes that included drywall work and painting.
Old 02-17-2013, 11:39 PM   #9
Always Learning
Rewards Points: 764
I think he said DIY job...been there..had to adjust glass for that...
Old 02-18-2013, 12:09 AM   #10
These folks listened to the supply house. They measured and ordered the original door, not knowing to take all the various tile and floor changes into account. We reordered a new door that with my labor and materials was less than just the door they had. Add in some miss cut doors and you have a comedy of errors. I'm just doing my part to help my buddies customers out.
We've been at this since October for scheduling and other various reasons. I'm just along for the adventure now.
Old 02-18-2013, 05:29 AM   #11
General Contractor
greg24k's Avatar
Rewards Points: 7,244
What ever you do while adventuring around that shower pan, try not to screw yourself, because anything from here on will be on you and HO can be funny when it comes to this...
I would hate to see you get into a situation, were you want to break a pointing at you finger.
Good luck
greg24k is offline
Old 02-18-2013, 12:02 PM   #12
Good luck
No doubt. I use lots of well placed silicone which usually does the trick. Next time I run into this situation it is a tall slider or nothing. With a slider, I can usually getaway with no screws in the bottom track.
Old 02-18-2013, 03:45 PM   #13
tubtime's Avatar
Trade: plumber
Rewards Points: 75
watch using inserts, we do hundreds of doors and repairs a year. inserts will cause spider cracking around the insert due to the pressure.
i think your in a bad spot with a prima hinge, only two screws in each . your threshold base hinge should be fine the upper i would worry about the sideway torque.
any pics of the shower?
tubtime is offline
Old 02-18-2013, 04:29 PM   #14
11678's Avatar
Rewards Points: 250
Drill hole in base.
Fill with foam.
Insert sleeve in hole, from floor to base.
Long screw from hinge through sleeve to floor.
JMHO
11678 is offline
Old 02-20-2013, 06:55 AM   #15
GO Remodeling's Avatar
Rewards Points: 96
Glue the bracket and tape until set. Lightly sand the spot and use polyurethane glue or silicone caulk. I wouldn't drill a hole at all.
GO Remodeling is offline
Old 02-20-2013, 07:09 AM   #16
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 703
Originally Posted by 11678 View Post
Drill hole in base.
Fill with foam.
JMHO
very smart man.
that is a great idea
"Quality work for those who know the difference"
nickko is offline
Old 04-04-2013, 11:14 PM   #17
shelf guy's Avatar
Trade: Custom Closets and Shower Doors
Rewards Points: 150
I am very familiar with Prima hinges (I just call them pivots) and I install tons of shower doors of all kinds.
If I were in this situation, I would simply explain to my buddy that I didnt want to get involved. I had a similar situation once that went sour on me, and the HO came to me for the fix.
I have installed grab bars into fiberglass using the Moen anchors, and even that is sketchy. I would not install 3/8 glass onto fiberglass without backing. NOT GOING TO HAPPEN.
shelf guy is offline
Shower question Joasis Plumbing 9 11-11-2014 08:32 PM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 06:33 AM
Sizing a Pole Light Base 5.4Lariat Architecture & Design 0 05-31-2012 01:45 PM
Scaffolding - Base Width Question ZachElwood Health & Safety 2 11-09-2010 01:09 PM
