Roman Spas
as per my last post, that i got made fun of, i figured out the name of what i wanted to build, its a roman spa, to me its just another tub
but anys this is what i want to build but simple one, meaning, bigger tiles, and square this way i dont have much mudding to do, ...........can i use mastic to build it or do it have to be mortar?
Custom Decks Custom aquarium all salt water Renovation next on my list............planting trees for all those material i used |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Roman Spas
Build it the same way you'd build a shower pan and a steam shower.
Mastic is a no-no. I think that's the stuff the professor used when he made the bathtub on Giligan's island. |
Trade: Kitchen & Bath
Re: Roman Spas
You can only go so big on the floor tiles since they will presumably be sloping to the drain. The most common rule of thumb I see is max 3 inch square, others say 2
Trade: Specializing in residential remodeling
Re: Roman Spas
Bigger tiles would be a real safety issue...that's why 'Roman Tubs' have penny squares install for slip & fall reasons. Here's an alternative for ya, just frame out a box drop in whatever (air/jetted or both) tub then tile around it...so much more up to date than a classic roman tub. Mike has the right anwser too NO MASTIC for this application, mud bed/thinset only.
Re: Roman Spas
NO MASTIC you mean i gotta actually learn to tile LOL,
so after i make my frame out of wood, then ply wood, then (waterproof membrane is that even necessary?) then thinset, my wall tiles would be small ones and for the flooring the really small ones on the sheet............................what do you guys recommend ...water jets or air? i think air would be cheaper, almost like an aquarium which way is better i know this one is old school frame, wire mesh, sling mud, then tile today frame, wire mesh, sling mud, liquid membrane, tile
#6 | |
Re: Roman SpasQuote:
Have you ever rough framed for any tub units? Set fixtures/drains? Installed GFCI's for pumps? Might want to read up on some information before attempting to take on such a timely project. Do you have any previous bath redo pic's other than the shower pic's? |
#7 | |
#8 | |
only weighs 5lb. per gallon. I suppose the people must not weigh anything, since they are floating in the water. ![]() Yes there are certain things GC's can't do. Like repeal the law of gravity.
#9 | |
![]() neo...
Handle It!
Re: Roman Spas
8 pounds 5 1/4 ounces per gallon.
Fill the tub with Gasoline and it will equal out to 5 pounds per gallon!!!!
Re: Roman Spas
well thank you all for your support and step by step on how to build a roman spa, tub, human aquarium, what ever it is, im gonna give my GC expoities and wire it up with 220V air pump and lots of mudding and gluing and ill post my pic by the 19th of oct
#12 | |
Proud Plumber
Trade: Plumbing/Building Contractor
Sorry, I couldn't resist........ October 19th cannot come fast enough for me.
Bill "I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett |
bathroom guru
Re: Roman Spas
Mastic??? Are you serious??
You are going to try to build a custom tile tub?? Do yourself a BIG favor - leave tiling to professionals who know what they are doing and what materials to use. We all can't be experts in everything you know (for example - I know how to build a house from the ground up - just don't ask me to do any wiring!)
| kinked supply for roman tub | lintjosh | Plumbing | 22 | 12-24-2007 03:22 PM |
| Roman Bathtub | blackdoggie | Plumbing | 1 | 10-08-2007 09:02 PM |
| Portable Spas? | ruskent | Pool Construction & Enclosures | 5 | 02-24-2007 11:40 PM |
