Recommended Shower Surround Adhesive?
Old 03-28-2009, 09:24 AM   #1
iceman61's Avatar
Trade: Remodeling, Roofing, Siding
Anybody have a recommendation for an adhesive for a plastic shower surround? I just noticed that Liquid nails states "not for plastic/vinyl".
iceman61 is offline
Old 03-28-2009, 09:28 AM   #2
KemoSabe
loneframer's Avatar
Re: Recommended Shower Surround Adhesive?
Look for a foam panel adhesive, I know some of the budget minded shower surrounds recommend this. liquid nails may dissolve the product.
loneframer is offline
Old 03-28-2009, 12:12 PM   #3
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
Liquid Nails does make a formula for surrounds too. About 50 cents more a tube, iirc.
olyteddy is offline
Old 03-28-2009, 12:21 PM   #4
Trailer park boy
shanekw1's Avatar
Buy the tube that says tub and shower surround adhesive.
shanekw1 is offline
Old 03-28-2009, 12:24 PM   #5
Remodeler Extraordinare
A.W.Davis's Avatar
http://www.hammerzone.com/archives/b...s/surround.htm
Not sure about that website, it was the first one that popped up on Google.
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 03-28-2009, 08:21 PM   #6
bathroom guru
jarvis design's Avatar
Its been probably 15 years since I have done a tub surround, but, we used to use tile mastic - spread on the walls with a 1/8" v-notch trowel.
Never had any issues, and you got a real good initial "stick"
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 03-28-2009, 08:27 PM   #7
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Yep 1/8 v trowel and just rip the tubes of adhesive open and use trowel, comes out tits.
willworkforbeer is offline
Old 03-29-2009, 02:12 AM   #8
iceman61's Avatar
Thanks for all the replies guys. I ended up using Loctite Power Grab Tub Surround Construction Adhesive. Seems to be holding like a charm so far but time will tell.
iceman61 is offline
Tiled shower leaks...Could use any advise at all... Jay22 Ceramic & Stone Tile 17 12-10-2008 07:15 PM
Using Regular Liquid Nails on a Tub Surround Second Look Remodeling 5 10-30-2008 07:18 PM
Shower Surround & Bathroom Questions Tommy C Ceramic & Stone Tile 16 04-18-2008 06:02 PM
Shower Surround Caulking Fix Needed LennyV-NHSNOLA Kitchens & Baths 0 09-13-2007 09:04 PM
Shower Surround stl_6string Drywall 4 01-02-2007 09:23 PM
