Preferred Substrate For Plastic Laminate Tops?
Yeah, that's pretty much the question.
Thanks. |
Re: Preferred Substrate For Plastic Laminate Tops?
Cabinets are the preferred substrate for laminate tops.
They don't require a rough top. If the cabinets have something to screw through to hold the top down, like the little plastic angled corner brackets or wood stringers, just use them. If there is nothing like that, then I would use 5/8 plywood to be sure it doesn't show beneath the front build-up on the countertop. |
Oh yeah, make sure you use screw short enough not to poke through the surface when you attach from below.
I guess I was asking more about making tops. On to what wood product is laminate typically applied?
Trade: finish carpentry
a fine particle board like an mdf works well but put solid wood on the ends for the end laminate to stick to better
Trade: GC/Remodeling
I've always used two layers of 3/4" particle board(not mdf or osb)..glued and screwed together. It makes a solid top, inexpensive, and the adhesive really bites in.
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
3/4" particle board, tite bond and staples. build up edges, and cabinet intersections. so when you screw up through the cabinet supports you are hitting material that is 1 1/2" thick, leave the other areas at 3/4" saves alittle material but mostly weight if they are big tops.
Re: Preferred Substrate For Plastic Laminate Tops? |
Particle board it is then. Thanks!
Trade: Kitchen & Bath
make sure to coat the underside of the particle board w/ a thick coat of poly where the steam from the dishwasher is going to hit it.
#11 | |
Re: Preferred Substrate For Plastic Laminate Tops?Quote:
I got a sheet of stainless too, and I'm going to try laminating a sheet of that. I got a 1/4" milling machine cutter I'm going to try in the router's 1/4" collet and see how that trims it up. |
| Getting laminate under door casing and jambs | Blackhawk | Flooring | 6 | 01-02-2008 04:14 PM |
| Laminate over Laminate | dayspring | Finish Carpentry | 16 | 10-03-2007 08:11 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
| Laminate Floor | Richard | Flooring | 15 | 12-22-2006 12:59 PM |
| Tile or Laminate | jwaldman97 | Flooring | 15 | 10-14-2006 06:41 AM |
