Designing YourImagination
Trade: Custom Remodeling
Is It Possible To Cut Cultured Marble Bath Tops?
I have a customer that we are finishing his bathroom and the top only has a 1/16" clearance. what could i cut off a 1/4" with? any help would be appreciated!!
Re: Is It Possible To Cut Cultured Marble Bath Tops?
Your circular saw with a normal carbide tipped blade.
Go slow or backwards to avoide possible blowout. A belt sander will work also, but 1/4" will take a little while. The stuff is pretty easy to work with. Wear a dust mask. |
Like send_it said. It's mostly polyester and marble dust. The marble dust is what kills tools/sandpaper.
hey guys thanks for your help. I have been told once before about a circular saw but wasnt for sure and wanted to double check before I screw up a top and have to buy a new one. Take care.
Trade: Residential Remodel
4" grinder with diamond blade.
Rich |
Trade: general contractor
I just did one last week with some advice from the guys on this site. I used a belt sander with a 50 grit belt. I had to scribe it to the wall on a remodel. worked great.
| cultured marble counter top | ponch37300 | Carpentry | 6 | 11-08-2007 10:28 PM |
| cultured marble repair | shelf guy | General Discussion | 3 | 08-16-2007 04:55 PM |
| Tiling over Marble??? | RussellF | Ceramic & Stone Tile | 5 | 01-27-2007 08:12 PM |
| White Marble Stained and needs Cleaned | ABLE1 | Masonry | 4 | 07-31-2006 10:34 PM |
| Cutting cultured marble | kenvest | Plumbing | 16 | 11-23-2005 09:54 PM |
