Old Bath Remodel
Old 09-03-2006, 05:15 PM   #1
my own boss
supercrew's Avatar
Trade: carpenter
Send a message via Yahoo to supercrew
Old Bath Remodel
okay i suck at ASKING questions.....
i have a remod....old....ripped up the flooring...old school....never seen it before....they cut the top of the floor/ceiling joist to a point....overlayed barbed wire over it to hold concrete.......then put thier ceramic on the created slab. PLUS they cut the little 2x8 floor/ceiling joist to run drains and water thru.....(guessin the hole saw wasnt available then)
to my dilima....
do i run an additional board along the top of the point to nail my subfloor too??? ????
i already know i gotta install metal gussets where the joist are cut....
i really hope my question askin abillities have improved.... any help would be well.....help......
supercrew is offline
Old 09-13-2006, 08:28 PM   #2
alter_ego's Avatar
Trade: General contractor
Re: Old Bath Remodel
to my dilima....
? Pics would be good. Got any?
alter_ego is offline
Old 09-14-2006, 09:49 AM   #3
tile mason
MattCoops's Avatar
sounds like an old mud job over lath
can you screw cement backerboard over sub and then tile?
MattCoops is offline
Old 09-14-2006, 09:54 AM   #4
Get the board stretcher!
TonyD's Avatar
Trade: Residential Building and Remodeling
I'm lost? PICS?
"...You cannot strengthen the weak by weakening the strong..."
Abraham Lincoln
TonyD is offline
Old 09-14-2006, 10:41 AM   #5
Moderator
Double-A's Avatar
This is common in this area. Blocking would be added down the joists, a few inches from the top, inbetween all the joists in the room. The flat top of the joinsts were beveled on each side so that they form a 'roof peak' instead of a flat.
A mud base is then set between the joists and sloped toward the doors, so the floor level there remains close to the same.
The reason the joists are cut back is to reduce the area the mud rests on the joists to keep it as strong as possible.
I made this in a hurry, hope it helps explain what he has.
New York Times, July 20, 2006
Double-A is offline
Old 09-14-2006, 05:28 PM   #6
tile mason
MattCoops's Avatar
Sketchup Rules!
nice one Double-A
Old 09-15-2006, 05:51 AM   #7
karma_carpentry's Avatar
Trade: carpenter
Yeah, I want to see a pic of this. Barbed wire ? Did you really mean barbed wire ? Not metal lathe?
I've seen lathe / cement / tiled walls but flooring ? I would think the cement layer must be pretty thick to be adequate support for a floor, at least 1-1/2" min.
karma_carpentry is offline
Old 09-15-2006, 11:25 AM   #8
tile mason
MattCoops's Avatar
it must be a prison floor if they used barbed wire
Old 09-18-2006, 02:01 AM   #9
My custom title
Brushslingers's Avatar
Lathe floors were very common in the 60's and earlier... and ya, most are about 1 1/2 or more thick. Barbed wire? Ehhh...
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-09-2007, 08:41 PM   #10
jiman3's Avatar
I would demo floor and plumbing to be replaced then sister the joists, leveling across tops. Then install new plumbing and subfloor.
jiman3 is offline
Old 05-09-2007, 09:20 PM   #11
wannabe
WNYcarpenter's Avatar
Trade: carpentry
I must be an idiot...a sharper point increases point load, the picture confuses me even more, what's the subtrate doing between the joists, below the joists? Am I crazy??? I'm completely lost here.....barbed wire? Wire mesh?
WNYcarpenter is offline
Old 05-09-2007, 09:36 PM   #12
wannabe
Trade: carpentry
I think I might understand...the joists are blocked solid a couple inches below the surface of the rough framing....the joistst are tapered so the adjoining cavities that are filled can be more cohesive, or not seperated as much at the surface by the "2" " joists . Before the developement of cement underlayment this was the process used to assure a ceramic surface planes out with other applied surfaces, such as hardwood and had enough structural integrity to resist cracks.?
Is this it or am I CFU?
Bath Fitter & 1 800 Bathtub cabela Flooring 2 12-05-2007 09:59 AM
remodel bath chris n Remodeling 6 08-08-2007 06:07 PM
SOS bath remodel: bizarre floor situation zmusashi General Discussion 9 07-29-2007 10:54 AM
Bath & Kitchen Remodeler wanted for Upstate SC SCDreamMaker Help Wanted or Looking For Work 0 05-23-2007 10:50 AM
Bath Remodel MattCoops Flooring 11 09-23-2006 08:39 PM
