Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Kitchens & Baths
Old 02-10-2009, 11:20 PM   #1
kitchen island spacing from cabinets???
I'm just wondering if there is a recommended spacing between the base cabinets and a kitchen island. I'm thinking 3 feet?
CronenBuilding is offline   Reply With Quote
Old 02-10-2009, 11:31 PM   #2
Teetorbilt's Avatar
36" will have you ADA approved and I go to 38"+ just to be on the safe side.
ADA will be a large factor in the near future as the baby boomers (me) retire.
Just re-read your post. 36" is total clearance so bases need to be -countertop overhang.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 02-10-2009, 11:38 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
36" between the countertops is a minimum, space saving if you will. I like to try for at least 42".
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 02-11-2009, 12:15 AM   #4
Trade: Designer for a residential design/build firm.
Try to leave 42" of space if you can. Here's the reason: Some refrigerators are almost 32" deep, leaving you with +/- 29" walkway at that area. If it's a 36" wide single-door refrigerator, the door will never open fully against the island.
Your mileage may vary.
If there are two cooks in the kitchen, the minimum recommendation is 48"-54" of clearance (usually in the larger kitchens.)
KitchenSync is offline   Reply With Quote
The Following User Says Thank You to KitchenSync For This Useful Post:
CronenBuilding (02-14-2009)
Old 02-14-2009, 12:55 AM   #5
Thanks a lot for the useful information. i apprerciate it.
Old 02-14-2009, 05:14 AM   #6
Trade: Kitchen & Bath dealer/remodeler
Here are the NKBA guidelines on clearances:
Guideline 1b. - Clarification:
If there are perpendicular walkways, one should be a minimum of 42" wide.
c. Work aisles (passages between vertical objects, both of which are work counters or appliances)
should be at least 42" wide in one-cook kitchens, at least 48" wide in multiple-cook kitchens.
more info here http://www.nkba.org/guidelines/kitchen_6.aspx
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems."
Margaret Mead
DesPro is offline   Reply With Quote
Google Seminars For Success... Ivinni Marketing & Sales 193 02-07-2009 08:22 PM
Sacrificing Kitchen Cabinets oadltd Remodeling 1 01-07-2009 01:42 PM
kitchen cabinets ronm1974 Remodeling 4 09-28-2008 11:24 PM
42" cabinets in eight foot ceiling kitchen kmd Kitchens & Baths 17 04-24-2008 08:08 PM
Painting Kitchen cabinets lornmastro Painting & Finish Work 15 12-06-2007 01:13 AM
