Cutting Hardi Back
Old 11-10-2006, 10:41 PM   #1
president/ owner
troyamuso's Avatar
Trade: Interior renovations
Cutting Hardi Back
Does anyone have a great way to cut hardi backer other than score and snap? I need to do more detailed cutting ie: L cuts, Circles etc. I'm new to the hardi backer world and neeed some help.
troyamuso is offline
Old 11-10-2006, 11:20 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Cutting Hardi Back
Dewalt 18vt cordless grinder and a diamond blade, is all we use. (bring extra batteries!) I've heard you can use power shears on it but have never tried that.
Mike Finley is offline
Old 11-10-2006, 11:26 PM   #3
Teetorbilt's Avatar
You can buy silicon carbide blades for a sabre saw. Never tried it but it should work for a while.
Albert Einstein
Teetorbilt is offline
Old 11-10-2006, 11:36 PM   #4
contractor
cmwacasey's Avatar
Trade: carpentry plumbing electric
power shears
cmwacasey is offline
Old 11-10-2006, 11:53 PM   #5
Teetorbilt's Avatar
For circles?
Albert Einstein
Old 11-11-2006, 12:49 AM   #6
contractor
cmwacasey's Avatar
for circles yes ,if you are a craftsman.sears craftsman no.
Old 11-11-2006, 06:57 AM   #7
DesPro's Avatar
Trade: Kitchen & Bath dealer/remodeler
Rotozip w/tile bit for circles
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems."
Margaret Mead
DesPro is offline
Old 11-15-2006, 07:44 AM   #8
Luxury Baths
highgear's Avatar
Trade: Historical Restoration and Custom Baths
For circles I always use circle cutter. I score it a couple of times and hit it with a hammer.Never fails and no dust from a grinder or roto zip
highgear is offline
Old 11-15-2006, 09:41 AM   #9
Chief Toilet Mover
By the way, what are these situations where circles are required to be cut in Hardi? I have yet to have ever run into a situation where I needed to cut a circle in this material.
Old 11-15-2006, 11:28 AM   #10
Thom
thom's Avatar
Like Mike, we use an angle grinder with a diamond blade. You can trim the edges to a perfect circle with that grinder if you so desire.
My plumber always comments that our tile cuts at the commode look so nice. Perfect circles at the edge of the flange. You can do it with the angle grinder.
thom is offline
Old 11-16-2006, 07:43 AM   #11
Luxury Baths
highgear's Avatar
circles are cut all the time when installing cement board on shower ceilings, and cutting out the shower valves. I cant undestand why you would want to make dust with a grinder when a circle cutter used for sheetrock can be used. You should give it a try.
highgear is offline
Old 11-16-2006, 10:01 AM   #12
Chief Toilet Mover
Why do you need to cut a circle around a shower valve? Even the tile placed over the Hardi around a shower valve doesn't need to be cut in a circle, the cover plate covers the hole, and even if you did want to cut the tile in a circle around the valve you still don't need a circle cut in the Hardi behind it. I've never yet found a reason to cut a circle in Hardi or any type of backer. Shower heads, shower valves, bath spouts all get square holes, toilet flanges get octagons.
We use a grinder for speed, dust is an issue, but it all gets cut outside anyways, also we have also moved to only using Hardi on floors, for all wet areas we use DensShield which cuts with a knife or a drywall hand saw.
Old 11-16-2006, 12:00 PM   #13
Bella D's Avatar
Trade: General Remodeling Contractor
I second the angle grinder and the diamond blade. I've tried the rotozip but it seems to take too long for me and I don't have as much control as I would like.
Bella D is offline
Old 11-16-2006, 02:06 PM   #14
president/ owner
troyamuso's Avatar
Mike,What are you using to cut an octagon in the hardi?
Old 11-16-2006, 07:18 PM   #15
Chief Toilet Mover
A Dewalt 18vt cordless grinder with a diamond wheel.
Except our is missing the handle and the guard.
Old 11-16-2006, 08:20 PM   #16
Tile Contractor
Bud Cline's Avatar
It is called "Pride of Workmanship". You can teach a monkey to hack a square hole, it takes a craftsman to cut a circle.
I'm gonna catch some hell now!
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Old 11-16-2006, 09:02 PM   #17
Chief Toilet Mover
No more hell to catch then I was expecting when saying I don't see any reason to cut a round hole.
Old 11-16-2006, 09:41 PM   #18
Tile Contractor
Bud Cline's Avatar
Just a few weeks ago I build this custom shower. It was one with 4 million spray heads and all the bells and whistles, you know the kind.
I had never seen this particular valve before so I went to the box and got their template and cut three holes in both the Hardi and eventually the tile just as the template said to do. Days previous I had asked the plumber if there was anything special I needed to know about this valve and of course he said "No". That ass hole had never seen one of these either.
So anyway I finish the shower, everything is fine, and the customer is exstatic with joy. About three days pass and the customer calls me.
He says his new valve control doesn't fit and neither does his escutcheon. So I rush right over there to find that I didn't need three round beautiful professionally executed holes in the stinkin' wall, all I needed was one big square hole that took-in everything, and also exposed the water calibrators in the wall that I had covered up.
Note to self: SELF(?) Don't ever believe anything anyone ever tells you. And when a plumber gives you advice, don't take it.
Old 11-16-2006, 10:42 PM   #19
Registered Tool Junkie
needthingsdone?'s Avatar
Trade: Residential New Construction
I can say that i've used the angle grinder to make "rough" cuts in hardi before, but the carbide blades from remgrit or lennox for a jig saw work so much better, create less dust and I find them to be much faster and quieter.
For gentle radius cuts and straight lines, shears are awesome and they cut way faster than anything else with no dust and lower noise.
Just my $.02
"It's not the first freakin' time I've done this you know!"
needthingsdone? is offline
Old 11-16-2006, 11:17 PM   #20
Chief Toilet Mover
Bud, did you have to find a monkey to cut that square hole out for you?
Hehe
Cutting baseboards in place when installing 72chevy4x4 Flooring 10 02-04-2009 05:08 AM
What's in your wallet -or- my back hurts mdshunk Health & Safety 19 04-26-2007 10:49 AM
Concrete Cutting - Dust Containment elvinstheman General Discussion 1 04-17-2007 01:08 PM
Boston Back Wrap JoeTedesco Electrical Picture Post 3 01-18-2007 10:51 PM
connections to the back of a switch 72chevy4x4 Electrical 50 11-17-2006 08:12 PM
