Cutting A Cultured Marble Counter Top
Old 02-26-2009, 06:08 PM   #1
rservices's Avatar
Rewards Points: 368
I need to trim a cultured marble counter top, does anyone have any suggestions
thanks
rservices is offline
Old 02-26-2009, 06:15 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,881
Re: Cutting A Cultured Marble Counter Top
Yep. That's nothing to screw around with. Take it to a pro shop that makes 'em.
By coincidence, just today for grins and giggles I tried trimming a 1x3 piece of marble with a diamond blade on my grinder. No matter how slow and careful I was, it chipped and flaked six ways from Sunday.
Fortunately, it was a waste piece that was being discarded anyway.
Tinstaafl is offline
Old 02-26-2009, 06:15 PM   #3
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Wood working tools work on it. (It's plastic & resin with some marble dust)
Big piece to cut off use a skill saw. Just a smidge you can work it with a belt sander. Wear a mask!
Mike Finley is offline
Old 02-26-2009, 06:20 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Oh, cultured marble. Slow brain this evening. The piece I was playing with was the real deal.
Carry on.
Old 02-26-2009, 06:26 PM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
thanks
I have had good results with a 24 tooth carbide blade, cutting from backside and starting from top edge of backsplash, then from front edge of counter, meeting at intersection. Be carefull to support so that the end of the cut doesn't cause chipping. Can be scribed to wall with medium grit beltsander, being careful of rotation direction to prevent chipping.
loneframer is offline
Old 02-26-2009, 06:30 PM   #6
Like Mike said, turn it over,
cut it from the back, and
support it so the cut piece
doesn't fall away.
I've used a carbide or diamond blade.
neolitic is offline
Old 02-26-2009, 07:54 PM   #7
Wolfgang's Avatar
Trade: Painting & Remodeling
Rewards Points: 502
I've always used a router. Gives a nice clean cut and no "dust" to worry about. I do wear a resp and safety goggles. The guy who showed me how to cut with a router was a manufacturer of cultured marble tops and panels.
Wolfgang is offline
Old 02-27-2009, 04:15 AM   #8
General Contractor
greg24k's Avatar
Rewards Points: 7,304
Good new carbide blade will do the job. Cut the top being upside down. If there is a wall on one or both sides, backsplash will cover any imperfections, if not straighten it out with a wet sander, sanding sponges work best.
Good luck
greg24k is offline
Old 02-27-2009, 11:09 AM   #9
bathroom guru
jarvis design's Avatar
Rewards Points: 560
I stopped using cultured marble a few years ago (got sick of it!!) but I have done lots in the past. I always used a masonry blade either in a skill saw or grinder (smaller one). No chipping - pretty clean cut.
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 02-27-2009, 11:22 AM   #10
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Abrasive?
Winchester is offline
Old 02-27-2009, 03:02 PM   #11
bathroom guru
Rewards Points: 560
Originally Posted by Winchester View Post
Abrasive?
Yes
I also used to use carbide grit jig saw blades for cut-outs
www.ExpressBath.ca
519-495-4062
Old 02-27-2009, 04:03 PM   #12
AustinDB's Avatar
Rewards Points: 598
does anyone have advise on 'polishing' surface abrasions? I set a paint can on the counter and it caused some scuffing.
AustinDB is online now
Old 06-10-2009, 05:03 PM   #13
mmike032's Avatar
Trade: trim carpentry
I had a builder call me today to see if I was interested in setting some vanity tops. So I checked it out and all of the tops will have to be trimmed to fit. the backsplashes are already built into the tops but the side splashes will also have to be trimmed to fit the profile of the backsplash.
Since only about 1/8" needs to come off the tops due to walls not square I'm thinking about trying to shave them with a belt sander.
is this a viable option to fit them to the wall. or would I be pissing in the wind trying to get 1/8th off with a beltsander?
forgot to mention that these are also cultured marble to the best of my knowledge
mmike032 is offline
Old 06-10-2009, 05:44 PM   #14
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
Rewards Points: 75
Exactly the same here. Cut from the backside starting from outer edges working in. I use my circular saw (sidewinder).
You can fine tune it with a grinder using a disc pad and 150 grit.
JamesKB2 is offline
Old 10-12-2012, 06:23 PM   #15
bozz's Avatar
Trade: cultured marb fabricator
When cutting its technique.masonry cutting blade is sufficient to cut through one inch or more. Using sawhorses to support your piece. Cut with shiny side down mark your cutting line on the rough side be sure to mark the back splash using a square to mark your line. With your lines marked it's.time to cut., now the technique part. Pull the safety guard back out of the way, cutting backwards starting at the back splash cutting upward till the saw cuts through the top line.then cut from the front of the top cutting backwards to the previous cut, be vary careful the saw will jump hard if you cut to fast. Do not cut like plywood.
bozz is offline
Old 10-14-2012, 04:28 PM   #16
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 7,922
Mike:
Put a 40 grit on your belt sander and it will grind off an 1/8" is short order with no chance of chipping. It's much easier to scribe with a belt sander than other tools.
Joe
Kowboy is offline
Old 10-14-2012, 05:04 PM   #17
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Originally Posted by Kowboy View Post
Mike:
Joe
I think mike moved on since June of 2009
Eaglei is offline
The Following User Says Thank You to Eaglei For This Useful Post:
I Mester (10-14-2012)
Polishing Cultured Marble Cuts neolitic Tiling 16 10-12-2012 08:57 PM
Cutting cultured marble counter top im4snow Kitchens & Baths 5 12-01-2008 05:35 PM
Cultured Marble Removal jv4511 Remodeling 9 04-07-2008 08:02 PM
cultured marble counter top ponch37300 Carpentry 6 11-08-2007 09:28 PM
Cutting cultured marble kenvest Plumbing 16 11-23-2005 08:54 PM
