09-14-2008, 10:52 AM
#1
Trade:
Remodeling & Home Additions
bonding Corian for countertops
if you were to use 1/4" Corian for a countertop application (or 1/2" I would guess), is it bonded to the underlayment-like a piece of 3/4" plywood? I understand the edging will be difficult, but doable. Found some Corian on the cheap and was thinking of a countertop.
another question, when using the Dupont bowl kits for Corian, guessing that's with 1/2" Corian, when manufactured offsite, is it brought in and bonded to the underlayment for strength? I'm wondering about the bowl area, if it is 'strong'.
09-14-2008, 11:02 AM
#2
Chief Toilet Mover
Trade:
Bathroom Remodeling
1/2 inch bonded to plywood, laminated edge of 3 pieces to create a 1 1/2 edge. Router the edge anyway you want to make it nice and purty. Sink is bonded off site and cleaned up so it looks purty where it bonds to the cut out sink hole. (forms what I would call an integrated sink)
Controversy exists with these sinks in regard to stress cracks forming around drain hole due to shock caused by hot and cold water. However most customer can't resist the temptation of going with a integrated sink to get that cool invisible connection instead of a safer porcelain under mount.
09-14-2008, 03:06 PM
#3
Trade:
thanks Mike. Concerning the stress cracks-do you suppose a double layer of Corian in that area (if possible) would help?
09-15-2008, 10:14 AM
#4
Chief Toilet Mover
Trade:
Bathroom Remodeling
The sinks are factory made and there are no flat surfaces on them so there is no bonding to be done. The cracks are around the drain, perhaps you thought I meant on the counter top?
09-15-2008, 11:14 AM
#5
Trade:
LI,NY designer, new homes, renovation work, concre
not sure, but is he talking about the connection between the counter and the sink?
09-24-2008, 09:22 PM
#6
Trade:
is the crack pictured located where the vent tube is formed (if it's formed into the Corian sinks)? I have not seen that type of crack before and had pictured something different.
09-26-2008, 06:42 AM
#7
Trade:
remodeling/specializing in kitchen & baths
thermal shock. acrylic based products warn against useing hot water only. things to consider
why would you bond 1/2" matl to a substrate? build up your edges and glue areas.
your gonna need a special gun for your seaming and bonding matl. i guess you could bbuy a tube, cut it apart, and mix manually but it dries fast and the cartridges run 50.00 ea
use a swanstone # 3015 dbl bowl sink if you want an integtal sink. 1/2 the cost of acrylic and no thermal shock. ps you'll need at least 2 bits for this, 1/2" shank and a heavy router
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
