Bathroom Handicap Grab Bar Install Height
Old 02-21-2012, 11:49 PM   #1
Dirtywhiteboy's Avatar
Rewards Points: 7,878
Is there a standard for this?
I've got to install handicap bars in the shower stall and bathroom wall
Dirtywhiteboy is offline
Old 02-21-2012, 11:55 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
Re: Bathroom Handicap Grab Bar Install Height
I think I'm glad your not installing them for me
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
The Following User Says Thank You to Tech Dawg For This Useful Post:
greg24k (02-22-2012)
Old 02-21-2012, 11:56 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Yes
ohiohomedoctor is offline
Old 02-21-2012, 11:56 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Randy,
This help?
http://www.adabathroom.com/grab_bar.html
griz is offline
Tech Dawg (02-22-2012)
Old 02-21-2012, 11:59 PM   #5
Tech Dawg's Avatar
For horozontal grab bars, I usually find that 36" from the floor up is a good height for most but it constantly varies when your mounting vertical and on angles. Get your customer involved so you can pinpoint a comfort zone.
Todd
Old 02-22-2012, 12:00 AM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Install per ADA guidelines, If there is ever a problem they will sue your arse for not complying with them.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
greg24k (02-22-2012), mr. greenwood (02-22-2012)
Old 02-22-2012, 12:05 AM   #7
Thanks Griz
griz (02-22-2012)
Old 02-22-2012, 12:05 AM   #8
Tech Dawg's Avatar
I know the guidelines and show correct locations etc... but in showers, sometimes the customer wants it a little higher or lower to suit their needs
Todd
Old 02-22-2012, 12:11 AM   #9
MikeyJP1980's Avatar
Rewards Points: 75
I think my codes official had me range them between 34” min. 38” max. 36” o.c. was our final placement from finished floor height. Backing is very important!
MikeyJP1980 is offline
Old 02-22-2012, 12:12 AM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 18
I do agree, but the ADA codes do have a range.
Just have to know your people.
I'm a liability nut,,,,
griz is offline
Old 02-22-2012, 12:22 AM   #11
There's no stinkin backin
+ YouTube Video
Old 02-22-2012, 12:23 AM   #12
detroit687's Avatar
Trade: carpenter
6" from the wall above the toilet 12" from the back wall
I go 35 1/2 to the top holes
detroit687 is offline
Old 02-22-2012, 05:55 AM   #13
Big Shoe's Avatar
Rewards Points: 1,720
When I go through a wall and there is no way to install backing from the opposite side I use anchors made for this. they are called Wingits. The anchor in the video looked fair(2 points) but the Wingit anchor grabs 3 points
As far as the height goes we nsed to run 2x8 34'' oc in all bath areas on all non residential work. standard ADA locations
If your putting in grab bars for a homeowner you can put them pretty much anywhere you/they want.
Good luck
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Dirtywhiteboy (02-22-2012)
Old 02-22-2012, 08:14 AM   #14
Aureli Construction
aureliconstruct's Avatar
Rewards Points: 75
You should check with your local laws before you establish the height.
www.aureliconstruction.com
aureliconstruct is offline
Old 02-22-2012, 10:46 AM   #15
mr. greenwood's Avatar
Trade: master carpenter
ADA is not going to get into residential worksites. they are too busy with a 4ft level and my sidewalks....
mr. greenwood is offline
Old 02-22-2012, 10:54 AM   #16
11678's Avatar
Rewards Points: 250
http://www.wingits.com/
I put them where the customer needs them.
A little 4'6" lady with osteo has much different needs than a 6'3" guy with bad knees.
11678 is offline
The Following 2 Users Say Thank You to 11678 For This Useful Post:
Big Shoe (02-22-2012), Dirtywhiteboy (02-22-2012)
Old 02-29-2012, 09:53 AM   #17
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
How did your project turn out? I', playing with these new lighting options from Elio and their new safety bar.
I used one amber light and one white light to see the effect this would create.
If the shower is dark these grab bars can offer up added safety.
JW
JohnFRWhipple is offline
Old 02-29-2012, 10:07 AM   #18
Mike-'s Avatar
Trade: Renovation Specialist.
Hey John, Now that my mother in law is going crazy... how is the illumination of this unit in your picture. Her place needs an upgrade..
Mike- is offline
Old 02-29-2012, 10:37 AM   #19
Mike the install is as easy as pie.
You get a power supply and your electrician installs the power supply and either sets it up with a timer, switch or photo cell switch. The low voltage wire can be directly tied into the LED lights with a quick connect concealed behind the rubber gasket.
I'm almost done playing with this sample I got and then I'm shipping it off to Angus for his review.
I love them and to raise the bar some (parton the pun) I'm going to go all custom and re an re the LED light with a colour changing option or perhaps fiber optic cables.
I think the safest install would be to use the white light with a photo cell switch. Maybe a "Clapper" to turn them on...
This gasket comes off with one screw and the light kit slips out.
Amber light kit (single - they make a high output 4 light as well).
Quick Connect terminal.
The first few changes I removed the entire gasket but found it was not necessary later in the day.
JW
Old 02-29-2012, 11:01 AM   #20
Mike-'s Avatar
As always John. Thank you for your descriptive answers. Huge help. Keep up the mint installs. They are fantastic.
Mike- is offline
Floor height problem DuFast Tiling 27 05-28-2011 02:14 AM
Handicapped ADA Bathroom Commercial SUPPLY - online ?? KYTravis General Discussion 5 12-09-2010 09:14 AM
Tile Floor - bathroom converted to den EricAnderson Flooring 2 06-23-2010 03:48 PM
Small bathroom stand alone hydronic heat? BaltimoreGuy Tiling 7 02-14-2010 03:13 PM
Bathroom Roll-in/Walk-in shower (for handicap) gemini_design Introductions 2 09-26-2009 12:01 PM
