Advice On Routing Laminate Top
Old 07-23-2009, 08:55 AM   #1
72chevy4x4
Guest
72chevy4x4's Avatar
Posts: n/a
I use to use a full size router w/ laminate bit and just picked up a laminate trimmer but still having the same problem when cutting back the top where the bit is going too deep and digging into the (already finished) sides. Can anyone provide tips to get my tops cut properly?
Old 07-26-2009, 11:42 PM   #2
TPI
Guest
TPI's Avatar
Posts: n/a
Re: Advice On Routing Laminate Top
are you using a bit with a roller on the bottom? I found that that works best
if not I have had some luck with a single layer of masking tape on the front drop. I have also heard of applying a thin layer of vasoline to the drop. I have not tried this method but I heard it to be very successful.
Old 07-27-2009, 12:05 AM   #3
user15686
Guest
user15686's Avatar
Posts: n/a
You need to use a bottom bearing bit that is set to cut just the thickness of the laminate.
Old 07-27-2009, 01:38 PM   #4
72chevy4x4
Guest
72chevy4x4's Avatar
Posts: n/a
I am using a flush bit with a bearing.
Old 07-27-2009, 01:55 PM   #5
J F
Guest
J F's Avatar
Posts: n/a
Try here:
http://woodworkersworld.net/laminate_trim_bits.shtml#sq
Old 07-27-2009, 02:07 PM   #6
bert0168
Guest
bert0168's Avatar
Posts: n/a
I don't have a solution but I may know the problem.
I bet it only digs in in certain places, right?
1. Your edge isn't perfectly square to the top.
2. You are tipping the router ever so slightly towards the center, probably don't know you are doing it.
I get the same problem sometimes and I know it's because of tipping the router slightly. Try an offset base that is longer on the inbound side and will allow you to keep the router perfectly flat to the top.
Old 07-27-2009, 02:08 PM   #7
bert0168
Guest
bert0168's Avatar
Posts: n/a
Where in DE?
I have relatives in Newark, went to UD and also have a beach house in Lewes.
Old 11-23-2009, 12:53 AM   #8
MarcD
Guest
MarcD's Avatar
Posts: n/a
You need to just practice, its hard at first putting a little weight on the top back of the trimmer as you go can do that. also going to slow seems to help mistakes. how big is your base on your trimmer ? I find not trimming on installed material but doing it on a nice base and workarea helps alot.
Advice wanted for starting a construction firm P.J. Construction 34 10-09-2009 02:51 PM
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 11:12 PM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 08:57 PM
need a little advice on laminate install Vabuilder Flooring 10 03-31-2008 10:04 PM
