What Is This Trowel Used For?
Old 12-27-2017, 04:26 PM   #21
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,472
Re: What Is This Trowel Used For?
Originally Posted by AustinDB View Post
what do you mean by premount? before the wall tile?
Had a row of 2" square mosaic on top of a half wall of tile and I was able to use the Raimondi clips-was nice b/c it pulled them out so they were in plane with the wall tile.
Probably on sheets of ditra.
Big Johnson is offline
TNTSERVICES (12-27-2017)
Old 12-27-2017, 04:35 PM   #22
tjbnwi's Avatar
Rewards Points: 2,570
I mounted these on Kerdi, have used Ditra to plane things out.
What is this trowel used for?-img_2197.jpg   What is this trowel used for?-img_2198.jpg
tjbnwi is online now
Old 12-27-2017, 04:40 PM   #23
AustinDB's Avatar
Rewards Points: 582
never thought of that, thanks guys.
I've been using strips of Kerdi and Ditra on rare occasions, to build out the mosaic but it's typcially difficult b/c the field tile above and below is already in place which doesn't leave a lot of room for troweling the thinset.
AustinDB is offline
Old 12-27-2017, 05:35 PM   #24
tjbnwi's Avatar
You can mount the mosaic, let it set, trowel the backer not the wall, set the band in place.
AustinDB (12-29-2017), TNTSERVICES (12-27-2017)
Old 12-27-2017, 07:14 PM   #25
Pre mount to Kerdi if the mosaic is thick, ditra if it’s thin. You can lay it on a bench and not worry about sag. I’ll fabricate a tool the thickness of the grout line and use it to create consistent grout lines throughout the sheet of mosaic. Leave the ditra (or kerdi) a little large, then trim it after the thinset sets and before installing on the wall. You can do long rows, then slap it on the wall the next day. So much easier and faster to work on a bench than on a wall.
Old 12-29-2017, 06:50 PM   #26
AustinDB's Avatar
Rewards Points: 582
Will this work with a diagonal pattern? Mount and setup, then cut it down the following day?
AustinDB is offline
Old 12-29-2017, 08:28 PM   #27
tjbnwi's Avatar
Yes. If you have a way to cut it.
Old 12-29-2017, 09:14 PM   #28
AustinDB's Avatar
Rewards Points: 582
Wet saw.
AustinDB is offline
Old 02-02-2018, 09:51 PM   #29
Bedfordboy116's Avatar
Trade: Construction/Remodeling
Rewards Points: 126
That is genius. Definitely trying that next time.
Bedfordboy116 is offline
What is your favorite trowel and how did you decide? LiteMortarBoard Masonry 28 11-14-2017 08:06 PM
Trowel Technique Kolbym Tiling 10 05-06-2015 04:41 PM
1/4" Trowel for Ditra? DemRem Tiling 17 07-10-2012 07:39 AM
Choosing trowel size depending on the tile size astor Tiling 5 07-04-2011 01:23 PM
lights on power trowel m1brown Concrete & Paving 1 04-30-2009 10:53 PM
