Trade: Contractor and Grunt
Rewards Points: 2,472
What Is This Trowel Used For?
Specifically.
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: GC PM
Rewards Points: 202
Re: What Is This Trowel Used For?
Larger format floor tile... 12x24 16x16... You get the idea. The u notch trowel allows the tile to bed down into the thinset a bit easier, with less build up in height over the subfloor. Also, U notch is less likely to trap air under the tile.
Do I pass? Sent from my SM-G930W8 using Tapatalk Advertisement |
The Following 2 Users Say Thank You to CPMKW For This Useful Post: |
TNTSERVICES (12-26-2017),
Tom M (12-26-2017)
#3 | |
Re: What Is This Trowel Used For?Quote:
Trade: roofing and other envied trades
Rewards Points: 936
Re: What Is This Trowel Used For? |
Rewards Points: 2,570
A square notch trowel will leave a bed of 1/2 of the dimensions as a mortar bed when the tile is set---1/4" trowel leaves 1/8" bed.
A U notch trowel will leave 1/3 of the dimension as a mortar bed. A 3/8" U notch will leave 1/8" bed. U notches are better for floors, you need a larger notch to get the same bed, on walls it can get difficult. As CP stated a u-notch is a little easier to bed in. Tom |
The Following 4 Users Say Thank You to tjbnwi For This Useful Post: |
#6 | |
So it’s made for doing a full mortar bed not thinset |
#7 | |
Rewards Points: 936
The Remodeler
Trade: Home Remodeler
Rewards Points: 228
No, it's still a thinset trowel.. The mortar bed he's referring to is thinset.
The Following User Says Thank You to Splinter For This Useful Post: |
Big Johnson (12-26-2017)
Thin set, medium set, works with either.
The bed is the amount of mortar thickness left under the tile after you push the tile into the mortar (bed the tile). Figuring the bed is can be difficult or easy, depending on how flat the tile is. This should help; https://www.rubi.com/us/blog/tile-trowel-size/ Tom |
The Following 2 Users Say Thank You to tjbnwi For This Useful Post: |
Big Johnson (12-26-2017),
MarkJames (12-26-2017)
Trade: Handyman Services
Rewards Points: 12,005
So basically....for floors getting large format tile.
I wish I knew that a couple weeks ago. I had just purchased two square notch 1/2 x 1/2's. Oh well. |
Another tip, something I discovered the hard way...
Porclien tile must be back troweled or back buttered. I found my back butter was inconsistent. I now use the Kerdi or Ditra trowel depending on how flat the tile is and back trowel them all. Ended up being faster for me. Tom |
#13 | |
The Following User Says Thank You to Big Johnson For This Useful Post: |
edward trowelhands
Trade: Diplomat
Rewards Points: 4,198
I always figured you get about 1/3 the thickness with a square notch trowel, assuming you spread at an angle. You get about 1/4" ridges with a 3/8 trowel. Then you half that by pressing the tile in and spreading it evenly.
Hair Splitter
Trade: General
Rewards Points: 3,326
Same here. Every tile gets backbuttered.
Sent from my SM-N950U using Tapatalk |
#16 | |
White backed glass tile--do you back butter? I never have. Mosaic sheet--do you wipe the backs? As I said, I found it's easier for me to back trowel with the Kerdi or Ditra trowel. Anything over 6x6 porcelain or ceramic I hit the back also. Tom |
#17 | |
I do not back butter mosaic. |
#18 | |
Hair Splitter
Trade: General
Backslashes is a different story. I flatten the thinset to achieve recommended coverage. Sent from my SM-N950U using Tapatalk |
#19 |
The Following User Says Thank You to tjbnwi For This Useful Post: |
#20 |
Rewards Points: 582
what do you mean by premount? before the wall tile?
Had a row of 2" square mosaic on top of a half wall of tile and I was able to use the Raimondi clips-was nice b/c it pulled them out so they were in plane with the wall tile. Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
What is your favorite trowel and how did you decide? | LiteMortarBoard | Masonry | 28 | 11-14-2017 08:06 PM |
Trowel Technique | Kolbym | Tiling | 10 | 05-06-2015 04:41 PM |
1/4" Trowel for Ditra? | DemRem | Tiling | 17 | 07-10-2012 07:39 AM |
Choosing trowel size depending on the tile size | astor | Tiling | 5 | 07-04-2011 01:23 PM |
lights on power trowel | m1brown | Concrete & Paving | 1 | 04-30-2009 10:53 PM |
Go to Page... |
