What Tile Project Are You Working On?
Old 06-30-2012, 10:28 AM   #2041
Bonzai's Avatar
Trade: Home Renovations & Repairs
Rewards Points: 252
Re: What Tile Project Are You Working On?
The damage pic I was trying to upload...
Renovations & Repairs. Bathrooms, decks, tile, paint & much more.
North Vancouver to Whistler and between.
TOLL FREE 1-877-804-3326
http://www.adventhomesolutions.com
Bonzai is offline
Old 06-30-2012, 10:58 AM   #2042
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Originally Posted by Inner10 View Post
Bare in mind I don't know my mouth from my arsehole when it comes to exterior finishing but my basic knowledge tells me in Ontario that wouldn't fly. Exterior finishing have to breath, if you want a water tight finish like stucco you have to put foam with vented channels on first.
And if I'm not mistaken you install electrical systems, low voltage systems, wiring and the lot?
Maybe you can help Craig with the finer points of home renovations. If I tell him, he won't listen.
JW
JohnFRWhipple is offline
Old 06-30-2012, 11:05 AM   #2043
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,452
JW
Automation, A/V, lighting control, networks, security and surveillance...I occasionally screw a piece of plywood onto a wall to put stuff on.
Inner10 is online now
Old 06-30-2012, 11:14 AM   #2044
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
This is a small section of the front of the house. The other 3 sides of the foundation are above grade. House breathes just fine.
Stop being a plumber and become a renovator and i might.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 06-30-2012, 11:30 AM   #2045
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Edit
ohiohomedoctor is offline
Old 06-30-2012, 11:32 AM   #2046
Kitchen tile job Springboro, Ohio.
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
tileman2000 (06-30-2012)
Old 06-30-2012, 11:38 AM   #2047
What type of screw? Course thread? Fine thread? Do you use a stud finder or not? Did you test the screw before installing? Use any wax or soap to ease installation? Was it philips or standard?
You need to know these things....
We pulled down an Ikea cabinet the other day my clients installed and the home owner drove in a 3 1/2" #10 wood screw to anchor the bracket on one stud. Lucky for him he didn't hit anything in the wall.
Old 06-30-2012, 03:07 PM   #2048
Screws? Ha! I only use galvanized 1/2"x8" lag bolts with double the washers and nuts tightened one on top of the other until I run out of thread...
Old 07-01-2012, 08:41 PM   #2049
Holding steady at 400 lbs.
What tile project are you working on?-screen-shot-2012-07-01-6.24.00-pm.jpg   What tile project are you working on?-screen-shot-2012-07-02-7.20.29-am.jpg   What tile project are you working on?-screen-shot-2012-07-02-7.23.20-am.jpg
Old 07-02-2012, 09:40 AM   #2050
Installed some under cabinet lighting in this bathroom.
Used a brass flat panel strip for a Heat Sink and just double sided tape to install.
Keep the LED strip back 6" from the face of the drawers.
What tile project are you working on?-screen-shot-2012-07-02-7.36.42-am.jpg   What tile project are you working on?-screen-shot-2012-07-02-7.36.36-am.jpg
Old 07-02-2012, 03:08 PM   #2051
Bonzai's Avatar
Rewards Points: 252
Cool idea. May use that one for my own master.
Bonzai is offline
Old 07-02-2012, 03:20 PM   #2052
Why do you need a heat sink with leds?
Old 07-02-2012, 05:23 PM   #2053
I believe it's so they last longer and don't over heat.
Some Mapeband and reinforcing fabric in the floating bench today
Installed a 3/4" L bracket as a heat sink for this cabinet on the same job
You can see the light through the window
Same warm led lights for kick and electric mirror install. I'm loving this FibaFuse drywall paperless tape
Old 07-03-2012, 09:12 AM   #2054
You guys see this?
Mapei's Eco Prim Grip
JW
What tile project are you working on?-screen-shot-2012-07-03-7.10.30-am.jpg   What tile project are you working on?-screen-shot-2012-07-03-7.13.12-am.jpg
The Following User Says Thank You to JohnFRWhipple For This Useful Post:
Ethos (07-03-2012)
Old 07-03-2012, 03:54 PM   #2055
John, as good as the tile work is the drywall patch is needing some attention.
Old 07-03-2012, 04:03 PM   #2056
Lol
I suspected some heat over that pass!
I'm on it. I'm going to sand the edges and give it the first of hopefully two top costs.
Had some cracking on my old work that I Need to fix up as well. Looks like the glass door hardware stressed the top corner of the entry way.
JW
Old 07-03-2012, 05:28 PM   #2057
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
You're late to class
http://www.contractortalk.com/f73/ti...m-grip-116975/
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
JohnFRWhipple (07-03-2012)
Old 07-05-2012, 06:27 PM   #2058
Inner10's Avatar
Well it ain't gonna win any awards but I'm happy with it. Laid the heated floor mat and buried it in Novoplane, it worked well but still left hills and valleys up to 1/8" that I had to compensate for.
Did all my cuts with a Sigma 2B3 and a grinder. Found some Ultraflex LFT, used LASH from home depot to, 1/2x1/2 notch trowel.
Only problem is I got more thinset on the face of the tiles than the back...got a lot of scraping tomorrow.
Couldn't have done it without all the helpful advice from Angus...cheque is in the mail!
PS I learned that setting tiles sucks, I ruined my pants and my fingers and knees are killing me.
Floormasta78 (07-06-2012)
Old 07-05-2012, 10:55 PM   #2059
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
Heated floors are always a PITA, unless you're magical with SLC.
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
Old 07-05-2012, 11:14 PM   #2060
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Angus
angus242 is offline
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Porcelain Tile over Hydroban/Densarmor? ApgarNJ Tiling 46 02-10-2011 09:39 PM
Saw these guys working out in front of the project yesterday wallmaxx Off Topic (Non Trade) 1 03-15-2009 06:54 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
