What Size Trowel?
Old 05-17-2008, 11:08 AM   #1
Remodeling Professionals
buildenterprise's Avatar
What Size Trowel?
What size trowel are you guys using for 8 x 12 ceramic wall tile over cbu for a tub surround? Also, what type Laticrete mortar would work well here?
buildenterprise is offline
Old 05-17-2008, 01:03 PM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: What Size Trowel?
1/4x1/4"
Modified.
R&D Tile is offline
Old 05-17-2008, 04:01 PM   #3
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Many times there will be a label on the trowel and it will tell you what notch trowels are used for certain sized tiles.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 05-17-2008, 04:29 PM   #4
nwtile guy's Avatar
Trade: Tile Setter
I might look at using a 1/4 by 3/8ths and use laticrete 253 gold. It is a good all around thinset, but a little pricey.
Chad
nwtile guy is offline
Old 05-17-2008, 08:06 PM   #5
R&D Tile's Avatar
I wouldn't go by that, the size of the trowel depends on the condition of the substrate, the backs of the tile and yes, size also.
R&D Tile is offline
Old 05-18-2008, 10:15 PM   #6
Sharp Improvements
I see your point on the backs of tile such as saltillo or so, using a larger notch. I guess I could have said "rule of thumb", have to be careful of certain advice at times. But what does the condition of the substrate have to do? Not being "smart" here but I would assume the condition of the substrate would be secure and flat.
Norman Sharp
Old 05-21-2008, 04:07 PM   #7
R&D Tile's Avatar
Yes, flat.
If it isn't and a small notch is used, you will have voids without placing more thinset to make up for it, be it backbuttering or a bigger notch.
R&D Tile is offline
Old 05-23-2008, 02:05 PM   #8
tile mason
MattCoops's Avatar
What will really gets you flubbed up is when your doing a pattern with two or more different tile sizes. Then the trowel label tells you you got to do the installation with a bunch of different trowels.
Man, don't think too much into it. Trowel some thinset, slap a tile down, and lift it right back up to see your coverage. Adjust if needed.
MattCoops is offline
Old 05-23-2008, 02:08 PM   #9
Remodeling GC
kevjob's Avatar
use the trowel sizing as a benchmark, the substrate and tiles will tell you what to use.
kevjob is offline
Old 05-30-2008, 08:23 PM   #10
bathroom guru
jarvis design's Avatar
A little something I just learned:
A lot of customers are asking for larger tiles - 18x18, 12x24, 24x24, etc.
I was using a 3/8"x3/8" for 13" tile so I went to a 1/2"x1/2" square notch.
I have been finding these installations a little tedious to get perfect (no lippage), and would end up back buttering before setting tiles.
What I found out today is that if you use a 1/2"x1/2" trowel on a 45 degree angle, by the time you smooth out your ridges you are left with about an 1/8" of mortor under the tile. I think I'll be changing trowel sizes or go to a medium bed installation. - anyones thoughts?
jarvis design is offline
Old 05-30-2008, 10:50 PM   #11
Sharp Improvements
For the those 24's you could get away with a 3/4x3/4 notch to give you a better bed for your tiles. Some tile stores carry them in 18''(not sure in cm) trowels.
Norman Sharp
power trowel banctecbobn Construction 4 09-02-2008 01:54 AM
what size trowel? Bill Flooring 7 04-21-2008 02:00 PM
Size of wire darren Electrical 6 03-29-2008 09:01 PM
Large Radius Cove Trowel Pauline100 Drywall 4 07-17-2007 08:47 PM
pointing trowel question roo Masonry 11 05-05-2007 08:09 PM
