Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring > Ceramic & Stone Tile
Old 08-29-2009, 10:34 PM   #1
Trade: carpentry
what is the best waterproof membrane under a tiled roof?
I will post this question as well in the tile section. I am building a garage addition that will connect to tiled decks on th esecond floor, The owner wants the tile deck to continue ove rthe garage addition, Its only gonna be about a 1-2 pitch rafter lenght is 12 feet i was thinking about a 1-2 inch drop since it will be a deck owner wants it flat as possible. My sales rep recommended this stuff called protecto wrap, never heard of it,, he says i can apply it over the plywood and thinset right over it? huh? he says its simular to water and ice...? anyone use this, or what you u recomend? i just never had to tile over a roof before, The tile is gonna be slate...
thanks for any info....
maleko is offline   Reply With Quote
Old 08-30-2009, 12:51 PM   #2
Trade: flooring
Where is this job located? cold climate?
check out Noble and Schulter websites for diagrams/plans. I'm not sure about Protecto wrap outdoors (I've never used it).
What is the existing method? How will the products tie-in together? What type of tile? Frost free, porcelain, etc? Are you the tile setter, too? This is a more advanced project for a newbie, if that describes you.
olzo
olzo55 is offline   Reply With Quote
Old 08-30-2009, 02:50 PM   #3
Tile Contractor
NONE of what you describe in your post is used in a tile roof. What the heck are talking about?
You should find someone in your area that has done this before. This is no time for you to be learning how to do it from guys on the Internet that also and equally don't know how to do it.
Bud Cline is offline   Reply With Quote
Old 08-31-2009, 08:05 AM   #4
Trade: flooring
tiled roof or tiled deck, Bud. yeah Noble has tiled deck products as well as Schluter. Now if it's a tiled roof like the Spanish styled roof that's a different thing. and, it's probably more than he would like to get into.
olzo
Old 08-31-2009, 11:28 AM   #5
Trade: carpentry
thanks guys i found what i need, its the Ditri - Matting from Schluter.
its floor tile , its going to be a tiled floor on a deck that has to double for the actual roof.
Old 08-31-2009, 12:55 PM   #6
Internet Creep
angus242's Avatar
Trade: Kitchen/Bath Remodeling, Tile
If there's a freeze/thaw condition, just Ditra won't be enough. You need to get the moisture from under the tile outta there. Maybe Troba is more of what you need.
...and you're just now hearing about Ditra??????
"If you're good at something, never do it for free."
angus242 is online now   Reply With Quote
Old 08-31-2009, 06:41 PM   #7
Tile Contractor
OK, now it's making a little more sense. STILL, as already mentioned, there is more to this than meets the eye. I don't think DITRA is the way to go in this case.
Old 08-31-2009, 08:12 PM   #8
Internet Creep
angus242's Avatar
Just so everyone knows what info is available and what advice is being given:
http://www.contractortalk.com/f11/he...le-roof-64119/
http://www.contractortalk.com/f15/wh...le-roof-64103/
No need to post so many threads on the same subject...
Old 08-31-2009, 08:50 PM   #9
Tile Contractor
Some Moderator should close two of those threads. Having three of them only serves to confuse and wastes a lot of time for some people. Look at the investment angus has already.
Old 08-31-2009, 09:13 PM   #10
Trade: flooring
Maleko,
Better check out that Schluter reference from Angus. There's a whole lot of stuff to know before you tackle this type of project. This isn't you ordinary tile job. There is a lot of skill and knowledge to pulling this one off. I also think you should look at Noble products for a comparison. Still think you should let someone with more tile experience handle this but if your gonna go ahead at least check out the references. And you really need to say where in the USA this project is so you can get advice for your location.
olzo
what i sthe best waterproof membrane to use under tile roof? maleko Roofing 17 09-14-2009 07:33 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 0 07-03-2008 12:53 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
