Wet Tile Saw Blades
Old 12-03-2011, 01:29 AM   #1
Mike-'s Avatar
Trade: Renovation Specialist.
Wet Tile Saw Blades
It's almost time for a new 10" blade for my Dewalt Wet Tile saw. I am not to familiar with what is available so I thought I would see what you guys use and what the consensus is on best performance. Budget is $200 and under.
Mike- is offline
Old 12-03-2011, 08:11 AM   #2
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Wet Tile Saw Blades
I'd imagine your first job will be put together a shopping list, then drive south. I've never used them and have only seen one shop that had them, but I've always been interested in trying the norton blades.
CO762 is offline
Old 12-03-2011, 09:07 AM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Raimondi T3 Razor. Next question.
Angus
angus242 is offline
Old 12-03-2011, 09:18 AM   #4
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
That was a quick thread
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 12-03-2011, 09:39 AM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
OK.
Raimondi Stealth
Raimondi Razor
Raimondi Glass Master (for glass obviously)
Now, next question?
Angus
angus242 is offline
Old 12-03-2011, 09:40 AM   #6
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Im with Angus on this one...cant beat the T3. Cant go wrong with the Stealth either.
Forget the dressing stones,use a piece of granite. Brings it right back to new.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 12-03-2011, 09:45 AM   #7
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Your always with angus :
ohiohomedoctor is offline
Old 12-03-2011, 09:46 AM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Or am I with Craig?
Angus
angus242 is offline
Old 12-03-2011, 09:49 AM   #9
Tech Dawg's Avatar
Angus is safe and sound in my truck :
Todd
Old 12-03-2011, 09:50 AM   #10
Originally Posted by angus242
Or am I with Craig?
Who's on first?
Old 12-03-2011, 09:50 AM   #11
Evan1968's Avatar
We're not together,together...not that there is anything wrong with that.
Craig
Evan1968 is offline
Old 12-03-2011, 09:52 AM   #12
Ohh theres something wrong with that.
Just pissin in cheerios .....
Old 12-03-2011, 09:57 AM   #13
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I hear I get let out every now and then
Angus
angus242 is offline
Old 12-03-2011, 09:59 AM   #14
Tech Dawg's Avatar
Nice PhotoShop job.....................
Todd
Old 12-03-2011, 10:01 AM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Ghetto editing.....Paint
and the discerning eye should know what's happening there.
Angus
angus242 is offline
Old 12-03-2011, 10:31 AM   #16
Mike-'s Avatar
Thank you... Close thread. Lol
Mike- is offline
Old 12-03-2011, 05:38 PM   #17
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
This. I haven't found anything yet the T3 won't cut and cut well.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 12-03-2011, 07:38 PM   #18
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
I'll third that, or am I fourth? Unfortunately mine was close to $300 with the taxes. But that's the blade
katoman is offline
Old 12-03-2011, 08:03 PM   #19
Tech Dawg's Avatar
Wow... That's around 200 bux in taxes...wtf?
Todd
Old 04-11-2012, 12:57 PM   #20
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
I need to resurrect this thread real fast. I have a bridge saw, however on some cuts, the blade (black widow) flexes and it isn't tracking as well as I'd like. This means I have to manually go point to point to get a straight cut, and cut from the top down in increments to get a perfectly square cut. It's a real PITA, and slows me down something fierce when I'm having to do precision cuts that show, like around a niche for example. It also has a huge tendency to deflect on thin shaves, where I might be shaving less than a 1/8".
I like the Raimondi T3 design with the thicker middle portion of the blade to stabilize it, but my bridge saw takes an 8" blade, and the T3 only comes in 10".
My questions is this:
Would anyone recommend the razor or the stealth for straightest tracking, or is there another brand you'd recommend? Basically, if you've used them, what are the pros and cons from your perspective of both those blades? I know that the stealth also does dry cutting, but it says it works for wet cutting too. I'm not concerned with having a thin blade so much, as a clean straight cut that won't deflect.
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
Commercial Ceramic tile on concrete slab removal TD40 Tiling 5 03-18-2018 07:26 AM
Tile Installation Failures in a High End Remodel ChrWright Tiling 139 03-04-2013 05:28 PM
Question for the tile & carpet Guru's RocknTJ Flooring 15 08-11-2011 09:01 PM
Tile Over Gypcrete Golden Rule Tiling 6 11-26-2010 03:00 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 07:01 PM
