Wet Bed For Ceramic Tile In Kitchen
Old 03-18-2008, 06:29 PM   #1
t2rocku's Avatar
Trade: mason
I'm thinking about putting wire mesh down on plywood subfloor and then use portland and sand to make the bed....Any thoughts or comments ???
thanks
t2rocku is offline
Old 03-19-2008, 10:20 AM   #2
R&D Tile's Avatar
Trade: Tile installations
Re: Wet Bed For Ceramic Tile In Kitchen
As long as there's also tar paper under the wire and the mud is 1 1/4" thick.
Ever do a mud job, from the sound of it, no.
R&D Tile is offline
Old 03-19-2008, 07:54 PM   #3
tile mason
MattCoops's Avatar
Hopefully you don't have to learn on someone else's property.
As said above, make sure you lay down a layer of moisture barrier before your lath and mud job.
And make sure to tak in consideration the height differences in adjacent rooms. You'll need some sort of reducer, be it stone, wood, or metal. Don't slope the mud down. I've seen that done before.
MattCoops is offline
Old 03-21-2008, 04:30 PM   #4
t2rocku's Avatar
Trade: mason
Yeah i do brick,stucco and stone ...but not flooring !!!
so , do you think i need to worry about flexing in the floor???
thanks
t2rocku is offline
Old 03-21-2008, 04:36 PM   #5
t2rocku's Avatar
Trade: mason
Matt
So i just square off at the door ways??? no sloping ????
t2rocku is offline
Old 03-21-2008, 05:07 PM   #6
Dan_Watson's Avatar
I dont know why this hasn't ben asked, but WHY a wet bed?!?!
Dan_Watson is offline
Old 03-22-2008, 09:29 AM   #7
t2rocku's Avatar
Trade: mason
backer board cost more then the tile .....
t2rocku is offline
Old 03-22-2008, 10:03 AM   #8
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I think you should just use a CBU as well. It is faster, cleaner and less expensive for you in the long run. Since you have not done wet beds, I would be leery to try it.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 03-22-2008, 10:21 AM   #9
nwtile guy's Avatar
Trade: Tile Setter
Backerboard is more expensive than mud, but have you considered the elevation? You could get ditra which only raises the highth of the floor an eigth inch or any other cement board that raises it a quarter inch. A minimum of a inch and a quarter is needed for a mud bed and most houses are not built to have that installed.
Chad
nwtile guy is offline
Old 03-22-2008, 12:13 PM   #10
Tile Contractor
Bud Cline's Avatar
If you don't use a full mudbed at 1-1/4" then deflection may become a serious issue. It may anyway.
Does your floor meet the necessary deflection criteria minimums for any of this?
Bud Cline is offline
Old 03-22-2008, 05:54 PM   #11
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
t2rocku,
You said, "backer board cost more then the tile ....."
What the heck kind of tile are you using?
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 03-22-2008, 06:12 PM   #12
R&D Tile's Avatar
Yeah, CBU costs about 70 cents a sq. ft., plus some screws and cheap thinset.
R&D Tile is offline
Old 03-22-2008, 06:18 PM   #13
Dan_Watson's Avatar
did a box store have a sale again? tile cheaper than $.69 a sq ft?
Old 03-22-2008, 08:18 PM   #14
Tile Contractor
Bud Cline's Avatar
Better varify the deflection criteria for sure. Did that tile come with a jar of cheese spread?
Old 03-25-2008, 07:46 PM   #15
t2rocku's Avatar
Trade: mason
Ok guys thanks...I'm going to use the 1/4 backer board ...
t2rocku is offline
Old 03-25-2008, 08:26 PM   #16
Tile Contractor
Bud Cline's Avatar
No conversation about deflection criteria and now all I can see is tail lights! It's no damned wonder the inspection business is growing by leaps and bounds these days.
Tile in my kitchen HELP Vinny Ceramic & Stone Tile 19 03-22-2008 09:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
flooded ceramic tile floor on concrete bmorrisey Ceramic & Stone Tile 2 12-06-2007 09:35 PM
tile removal issue at laundry/kitchen threshold Grainywood Flooring 7 10-17-2006 10:37 PM
Skimming over a Kitchen Tile Countertop atari Carpentry 8 06-09-2006 02:03 AM
