Water Damage To Ceramic Tile
Old 12-02-2009, 02:29 PM   #1
southernpride's Avatar
Trade: Remodeling/carpentry
Can standing water damage ceramic tile flooring?
southernpride is offline
Old 12-02-2009, 02:40 PM   #2
bathroom guru
jarvis design's Avatar
Rewards Points: 560
Re: Water Damage To Ceramic Tile
Only if it wasn't installed properly to protect against standing water
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 12-02-2009, 02:46 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Water can't damage tile. It can damage what's under the tile.
Angus
angus242 is offline
Old 12-02-2009, 02:53 PM   #4
could it cause the grout to loosen and crack therfore having loose tiles
Old 12-02-2009, 03:05 PM   #5
Tile Pro - Consulting
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Rewards Points: 352
As already stated standing water can cause problems when the substrate is not made to hold water. You see, ceramic tile does not make an installation waterproof. So, it's not the tile or grout's fault, it's the way it was installed.
Generally the only time a floor needs to be made waterproof is on a shower floor.
Will you tell us the type of room this is and exactly how and with what it was installed.
Jaz
TILE GUY - retired- TROY, MI - Method & Product suitability consulting.
MARBLE from ITALY & GREECE - PERLATO SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - NAXOS - others, Slabs - Tiles - Custom - marmo.sicilia@yahoo.com
JazMan is offline
Old 12-02-2009, 05:03 PM   #6
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
No.
Grout is not there to ensure the tiles stay bonded. It has no structural purpose.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 12-06-2009, 09:04 PM   #7
coveinspiration's Avatar
Trade: Tile Sles and Installations
Rewards Points: 75
If you wanna avoid damage put down kerdi under the tile. It's expensive, but it works. I don't think you can damage ceramic tile.
Colin
www.covefinishings.com
coveinspiration is offline
Old 12-06-2009, 09:48 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Kerdi under the floor tile......
Angus
angus242 is offline
Old 12-06-2009, 09:59 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,696
I use it closets!!
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-06-2009, 10:04 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Hell, with all the bickering in the drywall section, to hell with paper or mesh. I'm gonna start using kerdi-band for drywall seams!
Angus
angus242 is offline
Old 12-06-2009, 11:16 PM   #11
Rewards Points: 75
I use Kerdi in all my showers on the floor and walls.
Old 12-06-2009, 11:20 PM   #12
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
The OP was discussing floor tile, not shower tile.
Angus
angus242 is offline
Old 12-06-2009, 11:41 PM   #13
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
The sub floor is probably partical board or OSB which expanded when it got wet and is causing the results you are seeing.
Mike Finley is offline
Old 12-07-2009, 02:29 AM   #14
747's Avatar
Rewards Points: 1,000
There you have it. From the first guy who i would ask. Wow over 11,000 post. I remember when Michael was in the hundreds.
747 is offline
Old 01-15-2010, 06:05 PM   #15
Floor Artist
CapstoneMan's Avatar
Trade: Custom floor Artist
OK, back to the original question. Can Water damage ceramic tile, NO. Being I live in a flood area and I restore floors I have seen homes with 4' of water in them and the tile was fine. Then again I have seen homes with 2" of water in them and seen tile come loose. You have an option then. If your tile are loose then you can use Inject a Floor and reattach the tile with out damaging the grout. IF the gout is coming loose and cracking then you have other problems that need to be looked at. f this is on a pier and beam, or a wood subfloor it all needs to come out.
CapstoneMan is offline
Front Door water damage B_Boop Masonry 121 06-26-2009 01:25 AM
how many courses for ceramic tile shower walls? Bazooka Joe Tiling 19 02-14-2009 10:06 PM
Estimate On Ceramic Tile Buca1025 Tiling 30 02-03-2009 09:56 AM
Laying new ceramic tile on wall faromic80 Tiling 4 09-17-2008 07:01 AM
Ceramic Floor tile grouting John Walls Flooring 9 05-18-2007 06:42 AM
