Underlayment For 1 X 8 Subfloor
Old 07-30-2017, 07:07 AM   #1
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 52
What would you guys consider best underlayment for an install with 1 x 8 subfloor. Have an install for kitchen/dining room with the old 1 x 8 diagonal subfloor and adjacent rooms are hardwood on top of the 1 x 8's. Need transitions to hardwood level as possible. 12 x 24 porcelain tiles.
TCNA doesn't mention anything about this situation.
Any ideas other than replacing 1 x 8's with T & G??
Thanks.
goneelkn is online now
Old 07-30-2017, 08:01 AM   #2
gbruzze1's Avatar
Rewards Points: 2,608
Re: Underlayment For 1 X 8 Subfloor
If existing sub floor is sound, I'd put 1/2" ply and ditra over.
gbruzze1 is offline
The Following User Says Thank You to gbruzze1 For This Useful Post:
Golden view (07-30-2017)
Old 07-30-2017, 09:56 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,944
The only way to not raise the finished floor would be to remove the subfloor, use 3/4 ply and ditra.
Otherwise ply and ditra added is probably best. I've also seen cbu thinsetted down to the 1x8s. I don't trust that, especially with 12x24 tile.
Golden view is online now
Old 07-30-2017, 11:30 AM   #4
goneelkn's Avatar
Rewards Points: 52
Yeah, trying not to do replacing it, but might look like choice of that or higher transitions. Just wanted to see if anyone has any other thoughts.
Thanks.
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 05:59 PM
underlayment above subfloor? elementbldrs Tiling 17 07-21-2011 07:06 PM
subfloor problem jimh Flooring 21 02-25-2011 12:22 AM
Removing Porcelain Tile on Stapled and Glued Subfloor ParaDiddle777 Flooring 20 11-08-2008 09:48 PM
Best underlayment jscozz Flooring 0 07-03-2006 10:59 PM
