UGH! Schluter Jolly Metal Is 8 Ft. My Walls Are 8 Ft. 1 1/2 Inches
Old 12-27-2017, 09:14 PM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 887
small fill in cut, top or bottom of the corner. I was thinking at the top. Seems out of eye sight. I have 5 corners like this.
gowings is offline
Old 12-27-2017, 09:22 PM   #2
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 335
Re: UGH! Schluter Jolly Metal Is 8 Ft. My Walls Are 8 Ft. 1 1/2 Inches
rescraft is offline
Old 12-27-2017, 09:52 PM   #3
gowings's Avatar
Rewards Points: 887
here's a similar pic
You know for all the tiling I've done, I've never run into this issue where the run was longer than 8 feet on a vertical run. Since its that tiny of a remnant. A 1 1/2 inch cut to fill in
gowings is offline
Old 12-27-2017, 10:05 PM   #4
tjbnwi's Avatar
Rewards Points: 2,570
Jolly is 8' 2-1/2" long, not 8'
You'll need to cut off an inch to get it to fit.
tjbnwi is online now
TNTSERVICES (12-28-2017)
Old 12-27-2017, 10:17 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,675
Assuming it's too short regardless of the actual measurements, I'd do the splice at the bottom. People look down much more than up.
Tinstaafl is offline
Old 12-27-2017, 10:18 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Hmm. Shot myself in the foot with that one.
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
avenge (12-27-2017), tang (01-16-2018), Xtrememtnbiker (12-27-2017)
Old 12-27-2017, 10:19 PM   #7
tjbnwi's Avatar
If I have to seam the metal I place it at the lowest grout line. Done properly the seams will be invisible from normal viewing positions.
Old 12-27-2017, 10:22 PM   #8
tjbnwi's Avatar
I find the opposite, most never look up. I swear I could get away with no ceilings sometimes. Most look down more often when walking or just standing around.
The room is normally darker lower down with more shadows.
Old 12-27-2017, 10:27 PM   #9
Capra aegagrus
Tinstaafl's Avatar
That's what I said. But that actually argues for doing the splice up high where that spider guy is clutching the ceiling before pouncing on you.
Good point about the lighting down low, though.
Old 12-27-2017, 10:34 PM   #10
tjbnwi's Avatar
Higher it is closer to most lines of sight. Low the angle changes and is farther from most lines of sight.
Golden view (12-27-2017)
Old 12-27-2017, 10:34 PM   #11
gowings's Avatar
Rewards Points: 887
I was leaning towards up.
Thanks
gowings is offline
Old 12-27-2017, 10:38 PM   #12
gowings's Avatar
Rewards Points: 887
Anyone ever set the metal on the wall before starting to tile the wall. I do this a lot when i do shampoo niche's. Frame it and tape it to the wall.
gowings is offline
Old 12-27-2017, 10:38 PM   #13
tjbnwi's Avatar
Thanks
You shouldn't need a seam.
Old 12-27-2017, 10:44 PM   #14
gowings's Avatar
Rewards Points: 887
well I put the metal up on the corner to see what I was faced with and its 1 1/2 inches short
gowings is offline
Old 12-27-2017, 10:47 PM   #15
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,198
Yeah, most people's eyes are closer to the ceiling than the floor.
Golden view is offline
Old 12-27-2017, 11:49 PM   #16
avenge's Avatar
Rewards Points: 2,658
Well it has to be on the surface before you tile, sometimes I level it and hot glue it. I'd piece it in at the bottom.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Old 12-28-2017, 12:30 AM   #17
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,326
As long as the shower isn't across from the chitter.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 12-28-2017, 12:31 AM   #18
Hair Splitter
Trade: General
I always set the profile before tile.
The Following User Says Thank You to TNTSERVICES For This Useful Post:
heavy_d (12-28-2017)
Old 12-28-2017, 02:23 AM   #19
Jay hole's Avatar
Trade: General contractor
Rewards Points: 937
I like to do at least an 8" piece instead of an 1 1/2" tiny pieces never look right IMO.
Jay hole is online now
The Following User Says Thank You to Jay hole For This Useful Post:
Old 12-28-2017, 07:32 AM   #20
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,472
Not DWBs girlfriend Bridget.
Big Johnson is offline
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 11:18 AM
Metal Roof - Rain Diverter artinall Roofing 3 08-12-2012 11:00 PM
attaching metal lath to poured concrete walls with foam michiganmason Masonry 4 05-04-2012 09:03 PM
Ditra & Schluter Metal Edge Beanfacekilla Tiling 38 04-10-2012 09:37 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 07:30 AM
