Trade: Carpenter/GC
Tub-Tile Joint, Grout Or Caulk??
I've been doing more of my own tile work on recent projects, times being what they are, and I like doing it. In the middle of a bath remodel now and
am about to start the grouting. One question I hope to get some help with is grouting the joint between tile & tub. Which do you prefer, grout or grout caulk? Either way looks great when we leave a job because it is new. When I see jobs that were done not long ago with cracked out grout or mildewed caulk put in to repair a failed grout joint, I can't help but wonder if the failure is the product or the install. I see this with tubs and stone counters, most likely due to settling over time I've had the tub filled with water to help it settle. Any words of advice for me. Thanks in advance. Aframe |
Rock it...
Re: Tub-Tile Joint, Grout Or Caulk??
My guy uses grout caulk on the tub.
Remodeling GC
we fill the tub, then silicone and let it sit overnnight then drain tub.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
Trade: Carpenter/GC
holy crap you guys are fast
Tiling & Bath Contractor
Trade: Tiling & Bathroom Remodeling
Joints ALWAYS get caulk. If you're going to be doing more of your own tilework, I suggest ordering the Tile Council of America's handbook so you do the jobs correctly. One of the biggest mistakes I see when contractors do tiling is that they grout the corners. They grout everywhere- which is a major cause of tile failure.
Trade: Renovations
Ditto Fill tub caulk let sit overnight
#7 | |
Allrounder Home Services
Trade: Painting, Remodeling, Handyman
Re: Tub-Tile Joint, Grout Or Caulk??Quote:
Trade: Carpenter/GC
Re: Tub-Tile Joint, Grout Or Caulk??Last edited by Aframe; 02-17-2009 at 11:47 PM. |
Tub to tile,
wood to masonry, glass to metal, Always caulk joints between dissimilar materials. PolySeamSeal bath caulk is the longest lasting, most mildew resistant material I have found.
Hi Guys,
I have had the same issue happen twice now. After caulking the tub/tile joint with a bathroom silicon and letting it sit for at least 2 days (empty tub) it all seems to have hardened and looks good. Then once it gets wet for a while the caulk basically turns to gooo and can be wiped away. Any thoughts? Maybe 3 times is charm (ughh)?? |
#11 | |
bathroom guru
#12 | |
Its all ball bearings
Trade: Tile
Next time, try filling the tub before caulking. This will pull the tub down so you can completely fill the gap. Once cured, emptying the tub will only squeeze the silicone as opposed to stretching it when you caulk the gap with an empty tub.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
| Grout Vs. Caulk? | Liquid Force | Ceramic & Stone Tile | 28 | 06-22-2011 10:57 PM |
| Caulk at tubline... ...or grout? | Bazooka Joe | Ceramic & Stone Tile | 20 | 12-26-2008 02:39 PM |
| Grout for marble tile | bert0168 | Ceramic & Stone Tile | 20 | 11-04-2008 01:01 PM |
| Tile & Grout work | Paddy | General Discussion | 2 | 10-14-2008 09:17 AM |
| Tile grout color too light | fsbr | Flooring | 18 | 11-29-2007 06:05 AM |
