Tub Surround Hydrology
Old 10-03-2008, 11:07 AM   #1
punkab's Avatar
Trade: framer
You go to a lot of effort to prevent water from entering the wall cavity. If water gets behind the tile (which I'm presuming will happen, otherwise why worry about it in the first place), where then does it go?
I'm roughing in a window in the wall above the tub in a small bathroom remodel. There's some rot in the wall and it makes me curious about waterproofing a tile tub surround. You put a poly sheet or felt over the studs, then backer board over that membrane, then thinset the tile down, grout and seal, and caulk corners. The two questions that come to my mind are: don't nail/screw penetrations from the backer board ruin the membrane? And shouldn't weep holes be left in the caulk where the tile meets the tub? I know it gets pretty wet down there, so maybe skip the weep holes, but then where will the water that gets behind the tiles go? Won't it just ride up the membrane until it gets to a penetration and leak into the wall if you caulk the bottom edge of the membrane to the tub flange? Or leak behind the membrane into the wall if you don't?
Is this hypothesis correct: some water will get behind the tiles. Sealing up the surround to keep the water within the backer board/tile envelope will only permit so much water to exist there. The moisture will eventually evaporate back out of the tile surface from where it first came. Penetrations in the "waterproof" membrane are negligible paths for the water to escape through. Doesn't make sense to me. Seems like if water gets back there, you'll just have a poochy membrane with pockets of water pooling up at the bottom until it finds a way out, probably at a poorly sealed corner or penetration and into the wall cavity.
PunkAB
punkab is offline
Old 10-04-2008, 11:21 PM   #2
tile mason
MattCoops's Avatar
Re: Tub Surround Hydrology
You're thinking too much into things.
If you follow recommendations in the TCNA handbook and install your products to manufacturers' specifications you won't have any problems.
Just follow the "rules" and you'll be ok.
MattCoops is offline
Old 10-05-2008, 12:24 AM   #3
Tile Setter
Tileworks's Avatar
Trade: Ceramic Tile, Marble, & Stone
Remember, we have gravity on our side, so water is going to run down. A very small amount of moisture may penetrate the sealer and grout, and get behind the tile. Then there is 1/2" of backerboard to find it's way through only to hit plastic. Granted, there are nails in the backerboard and into the studs, but I doubt moisture will every find it's way there. Your tub surround would have to be submerged by a flash flood.
If all this still keeps you lying awake at night, then forego the plastic on the studs behind the backerboard, and coat the surface of the backerboard with Redgard or similar product instead. This way, the tile is adhered to a waterproof surface... even the nails are protected!
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline
Old 10-05-2008, 01:47 AM   #4
Remodeling GC
kevjob's Avatar
kerdi
kevjob is offline
Old 10-11-2008, 08:18 PM   #5
bathroom guru
jarvis design's Avatar
Concrete board with Kerdi!!
jarvis design is offline
Old 10-12-2008, 12:45 PM   #6
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Originally Posted by kevjob View Post
kerdi
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 10-12-2008, 02:25 PM   #7
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
YUP, Kerdi. Only way to make it waterproof for me.
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 10-12-2008, 08:28 PM   #8
tile mason
MattCoops's Avatar
Anybody ever do a Kerdi shower more than 15 years ago?
I know it was first introduced in about 1987. But I never touched the stuff til about a couple years ago.
Just curious to see how long people been using them for.
Old 10-13-2008, 09:21 AM   #9
bathroom guru
I have been using Kerdi for about 4-5 years - used it the first chance I got when I learned about it!! - Used it ever since
Tiled Tub Surround Sparky Joe Ceramic & Stone Tile 34 09-05-2008 06:08 PM
Shower Surround & Bathroom Questions Tommy C Ceramic & Stone Tile 16 04-18-2008 06:02 PM
Tub Surround dragonfly Plumbing 18 03-20-2008 10:07 PM
Kerdi Tub Surround Graeson Ceramic & Stone Tile 12 03-13-2008 06:12 PM
Shower Surround Caulking Fix Needed LennyV-NHSNOLA Kitchens & Baths 0 09-13-2007 09:04 PM
