Tiling Tub Surround
Old 03-20-2011, 01:25 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Question
Tiling Tub Surround
Is it ok to put green sheetrock around a tub and put tile to it with mastic? or should there be cement board around the first 2 feet and then swap over to sheetrock?
bluebird5 is offline
Old 03-20-2011, 01:32 PM   #2
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Re: Tiling Tub Surround
Oh boy, nothing about that works at all. CBU the whole thing as a minimum and use the mastic for, well, use the bucket to sit on. None of that combination has any business in a wet location
Keeyter is offline
The Following User Says Thank You to Keeyter For This Useful Post:
JumboJack (03-20-2011)
Old 03-20-2011, 01:52 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Can it be done that way to some sort of success? Yes.
However, why? By simply using a liquid membrane and thinset, you've just eliminated any potential problems. If you are doing a liquid membrane, you don't need cement board. Just cover the entire area. or you could use cement board and just liquid over the seams and screw holes. Or you could use DensShield and liquid the seams and screw holes.
You have options, I just wouldn't use green board and mastic.
BTW, green board has been removed from the IRC for 2006.
Angus
angus242 is offline
Old 03-20-2011, 01:53 PM   #4
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 228
and dont forget 4 or 6 mil clear poly on the studs, over the lip of the tub.... Be sure to use proper alkali resistant mesh tape on the seams and corners set with thinset. (powdered thinset, none of that pre-mix junk)
Splinter is offline
Old 03-20-2011, 02:07 PM   #5
bluebird5's Avatar
Rewards Points: 694
Well that is what I was wondering because it is just a tub and not a tub shower combination if you still need the waterproofing. I don't spash water all over the walls when im playin with my rubber duckies. Angus, mapie aqua defense or redguard ok for sheetrock (mold resistent)
Old 03-20-2011, 02:13 PM   #6
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Yes, you can use Mapei AquaDefense over drywall. Although, what's the use of having moisture resistant drywall if it's covered by a liquid membrane?
Angus
angus242 is offline
Old 03-20-2011, 02:13 PM   #7
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
Rewards Points: 810
Lightbulb
never could figure out why people spend so much time, money and effort to do it wrong when floating is just so easy.
we're not in Kansas anymore Toto
essrmo is offline
Old 03-20-2011, 02:16 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
You mean mud walls?
I can do it 3x's quicker without.
Angus
angus242 is offline
Old 03-20-2011, 02:53 PM   #9
Maxi-Pier Tech
essrmo's Avatar
Rewards Points: 810
Question
Originally Posted by angus242 View Post
You mean mud walls?
without an intregal drainage system ?
essrmo is offline
Old 03-20-2011, 02:54 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
For a tub surround?
Angus
angus242 is offline
Old 03-20-2011, 04:26 PM   #11
Maxi-Pier Tech
essrmo's Avatar
Rewards Points: 810
Cool
especially for a tub surround.
essrmo is offline
Old 03-20-2011, 04:43 PM   #12
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Not really sure at what you're getting at. What does a tub surround have to do with an integral drainage system?
Angus
angus242 is offline
Old 03-20-2011, 04:56 PM   #13
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Mud is not waterproof. Are you then covering the mud with a liquid membrane?
I'm as confused as Angus
katoman is offline
Old 03-20-2011, 05:03 PM   #14
Maxi-Pier Tech
essrmo's Avatar
Rewards Points: 810
water get in and needs to be channeled out. when the water can not get out, it backs up
and stacks up in the wall until if finds a place to weep out.
as the wall becomes saturated, mold, dryrot and structural damage set in,
The cure is too make the third coat (tile) waterproof. which demonstrates my first and second points (time and money).
essrmo is offline
Old 03-20-2011, 05:06 PM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Why let water in and the allow it to get out if you can just keep it from getting in at all?
Like I said, I can I perform the "keep water out altogether" method much quicker. Perhaps others prefer other ways. I was just answering the OP's question with my opinion.
I seriously doubt that in this situation, with the person who asked the question that a floated tub surround wall is the advice needed.
Angus
angus242 is offline
Old 03-20-2011, 05:08 PM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
and tile isn't waterproof...thus the necessity of waterproofing behind it.
Angus
angus242 is offline
Old 03-20-2011, 05:10 PM   #17
Maxi-Pier Tech
essrmo's Avatar
Rewards Points: 810
Lightbulb
liquid membrane (waterproof barrier) is not nessesary if you provide drainage.
yes, (properly built) masonry walls have intregal drainage systems. rather than explain it to people who , just look it up.
essrmo is offline
Old 03-20-2011, 05:11 PM   #18
katoman's Avatar
Trade: carpenter
I understand now, you rely on the grout to be waterproof. No issue with that. But as Angus has said there are faster ways than mud walls.
Not saying anything wrong with mud.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
essrmo (03-20-2011)
Old 03-20-2011, 05:22 PM   #19
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I'm still confused.
Cementitious grout has an absorption of around 7%-9%. How is that waterproof?
Angus
angus242 is offline
Old 03-20-2011, 05:33 PM   #20
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
ok they hell with the two goof balls. Hang some Durock NEXTGEN. Mud the seams and install some LATICRETE hydroban and call it done. If water goes thru HYDROBAN I will walk into the whitehouse nude and be on CNN
opiethetileman is offline
The Following User Says Thank You to opiethetileman For This Useful Post:
bluebird5 (03-20-2011)
Tiling suggestion needed for block walls user61815 Kitchens & Baths 1 05-17-2010 10:35 PM
field tiling Big Chris Excavation & Site Work 5 02-15-2010 12:21 PM
Tiling around a Sterling tub? baspinall General Discussion 5 01-27-2010 02:25 PM
Using Regular Liquid Nails on a Tub Surround Second Look Remodeling 5 10-30-2008 06:18 PM
Tiling up to a window on a surround healthyhomes Carpentry 1 04-15-2008 06:32 PM
