#21 |
Trade: Tile installations
Re: Tiling Shower And Seat
You never thinset to poly, not sure what you are stating, I'm in Hicksville neighbor.
And as far as the screws, what are you using them for, the CBU, once moisture gets under the slab or through it and it WILL, it will rot everything out, believe me, I know, ripped many out. Going to bed now, have to get up early for work, will continue this tomorrow. |
#22 | |
Re: Tiling Shower And SeatQuote:
#23 |
Tile Contractor
Somebody show me where all of this nonsense is located in any of the tile installation handbooks please. You can't simply glue any cement board to anything, no way that will last.
#24 |
Tile Contractor
So.....where's the picture that was promised? That would be a big help.
#26 | |
somebody show me where all of this nonsense is about not being able to glue cement board, it does last, goodnight all, i am tired, G
#27 |
I give up, that link is nonsense and all of this is incorrect, except what I have stated so far as to how it SHOULD be done.
I'm now done with this thread and good luck to those who install it their way. |
#28 |
Remodeling GC
just use a better bench and kerdi from now on.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
#29 |
Trade: Tile Contractor
Best thing before you start tiling is to durock the seat top and front face and use galvanized or stainless steel drywall screws and silicone the heads so its water proof again, when you do that make sure silicone the back of te durock and stick it to the liner also. If you will still tile the top and face I recommend that you use bigger tiles and use thin-set instead of glue, that will make it stronger and long lasting, Start finishing front face and around shower first and finish top part of the seat. On the front top edge and side of the seat you should use matching bullnose so tip of the tile does not hurt people. I would also recommend that you use thin-set up to 4 feet high in the shower area and the rest you could use glue if you want.
You should mud and tile shower pan floor after durocking and then start doing everything else. This is the best you can do, but if you want a comfy seat spend some money and buy a 1 piece slab that matches the tile. better looking, longer lasting easier to maintain. NOTICE:This is best of my knowledge and it is your responsibility to do the job right, please do not blame it on me if you do something wrong or job does not come out the way you want. |
#30 |
Trade: framer-inside/outside trim- asphault roofing/remoldeling
sorry for the no pics and all the arguing going on but here the pics.
passingwindII
#31 |
well you definately need another piece of liner to replace with the existing . Your plumber is no good!! He should have installed a single piece I see that seat membrance and shower floor membrance is two different pieces. NO GOOD!!!!!
#32 |
Full Service Renovations
Rip that liner out....... It is in no way a waterproof membrane in the state it is in. Get a book and learn how to install Kerdi. Schluter Systems offer several complete shower kits with everything you need to do a proper "WATER PROOF" shower.
#33 | |
![]() I doubt there's a even a pre-slope from what I see in those photos. And, if you continue with that shower the way it is, you will be in BIG trouble real SOON... Enough of this, it's wrong, needs to be completely redone correctly. ![]() Oh and, not even going to start with the curb, that's another story, not to mention the liner is about 8" too low, forget it, done ranting, good night. Last edited by R&D Tile; 09-29-2008 at 09:15 PM. |
#34 | |
#35 |
Trade: home remodel/deck builder
I'd tear the bench and membrane out and start over, a shower constructed like that will never last. You may consider using block for your bench on top of the liner.
#36 |
Remodeling GC
please tell me that is not a steam shower.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver Last edited by kevjob; 09-29-2008 at 10:21 PM. |
#37 |
It is not even shower, it is a steam room! wont even last 3 months like this, big trouble! rip it out and have a licensed and experienced plumber reinstall the liner for you.
#38 |
Trade: General contractor
Wow, is all I can say...
Where is water that makes it under the tile supposed to go, under the seat into the framing? If the pan and seat WAS waterproofed correctly, Id say the answer is to mud the pan and seat. Doesn't seem like too many people do that anymore, but thats what we do on all our showers, seat or no seat. We use hot mop out here...sometimes you run into the rubber liners, but most are hot mopped. |
#39 |
one piece needs to be used, and it must include the curb, also the face of the seat face must extend, not terminate tight in the corner, glue should be used to stick to substrate, other than that, YOUR FINE.
uh oo, just noticed the face of the bench is not sheathed either, that is CRAZY, entire bench needs to sheathed first, then liner, the wonderboard, if you are using that type of system...liner also needs to come further up wall, as far as preslope, not required here, tile guy SHOULD handle slope with muddddd
