Tiling Over Concrete Expansion Joints
Old 08-16-2007, 01:26 PM   #1
Clueless's Avatar
Trade: Tile
Question
Is it possible (smart?) to tile over expansion joints on a basement concrete floor. They're not moisture prone it seems. My thought was to fill the joints with level quick, then to put red guard over top, then use a membrane additive with the adhesive. Should I be considering this at all? Is there some alternative (short of lining up grout lines with the joints) that could be considered?
Clueless is offline
Old 08-16-2007, 02:24 PM   #2
Clueless's Avatar
Trade: Tile
Re: Tiling Over Concrete Expansion Joints
I may have misdefined the joint. I am not necessarily sure it is an expansion joint. However it is a definite 1/4" break line, from one concrete slab to the next. Could it be just a construction joint? How can you tell?
Clueless is offline
Old 08-16-2007, 03:43 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
If it's a cut of any kind in the concrete you run the risk of slippage & movement that will translate through the grout & possibly even crack the tile (especially with natural stones). Is this newer concrete or old? Has there been any seperation in the joint that you can see?
If the concrete is stable and fully cured--you can tile over this but you need to provide a slip membrane beteen the concrete and the tile.
Two great products for this are Schluter Ditra (comes in rolls and works very well over concrete) or Laticrete blue 92.
Go to the schluter website and look at the ditra page. They have a great video that shows the principle behind the product and the installation method.
I'm not sure what you're referring to by "adding a membrane additive to the adhesive". Do you mean a latex additive to the thinset?
If the concrete isn't stable or the slab is subjected to constant movement and/or changes in moisture (an older house without a perimeter drain for example), then it still might not be advisable to tile over it--even with an isolation membrane.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 08-16-2007, 05:25 PM   #4
Professional Remodeler
firemike's Avatar
A less expensive alternative would be to use a Schluter Dilex product and center it right over the control joint. That way, if it does move, you shouldn't have any problems.
Chris brings up some valid questions too. How old is the concrete, what kind of shape is it in, have you done a moisture test yet, does it look like it has moved, how flat is it, is there any type of finish, sealer, etc. The answers to these questions will allow a more accurate answer.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 08-16-2007, 06:11 PM   #5
Thom
thom's Avatar
Start your layout on the joint. If you have shifting slabs the grout will crack out and you can replace it with the matching caulk.
thom is offline
Old 08-16-2007, 10:38 PM   #6
Clueless's Avatar
Trade: Tile
It's 4 year old concrete and largely is in good shape. Minor hairline cracks, and relatively level throughout. There appears to be no cracks around the joints themselves.
I do mean a latex additive to the thinset. Generally the joints look ok, and the floor is in good shape. Just wasn't sure if I wanted to approach this at all.
Is Red guard any good?
Clueless is offline
Old 09-19-2007, 01:50 PM   #7
Sauna & Steam - Remodelin
Flacan's Avatar
Trade: Remodeling / Sauna & Steam
If there hasn't been any movement to this point, odds are that it's stable.
However, you should never have to guarantee that.
I can't help you with product, been out of that game for a while.
Raimo Kumpulainen
Those who don't remember the past, are condemned to repeat it.
Flacan is offline
Old 09-19-2007, 02:32 PM   #8
Knowledge Factory
Floordude's Avatar
If it were my home, I'd totally skip the tiles, and score the concrete to look like tiles, incorperating the control joint into the design, and then acid stain.
www.acidstain.com
www.scofield.com
These are all stained concrete. The cost is much less expensive then tile installation.
http://www.AustinFloorguy.com
Floordude is offline
Old 11-09-2007, 12:20 PM   #9
CCSowner's Avatar
Trade: Tile/Stone
WHAT HE SAID ^
Adam Forsythe
Creative Covering solutions
"New England's Answer to Brick paving and Tile/Stone"
www.creativecoveringsolutions.com
CCSowner is offline
Old 11-09-2007, 06:14 PM   #10
reveivl's Avatar
Trade: Renovations
Neat stuff, Floordude, you should write an essay on that stuff. (And post more pictures!)
reveivl is offline
Old 11-23-2007, 04:15 PM   #11
Stacy Moran's Avatar
Trade: Hard surface flooring installer
Thumbs up
They make a joint expansion tape. do not fill expansion with thinset! The expansion is needed...Do not start your grout line their - center off as you should and put the expansion tape on - you can get it on line - or order it from a flooring store - if you do it any other way you WILL get bad results over time that will cause you a rip out job! Dont want that when the tape is cheap - proper - easy to put down.
Stacy Moran is offline
Old 11-23-2007, 04:19 PM   #12
They make expansion tape just for this - Order it on line or at a flooring store - any other way will give you bad results over time
Old 11-25-2007, 06:20 PM   #13
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Expansion tape isn't even close to enough. First, at a minimum, you need a membrane that will cover atleast one full tile on either side of the crack. Several examples would be Laticrete's 9235 (Blue 92), Noble's CIS sheet membrane, Hydroment's Ultraset-- any of those would work. The next thing you need is a movement joint. The only thing the membrane will do is allow you to "move" the movement joint so you can make it fall full tile. Now, you can either use a matching siliconized latex, or, as someone suggested, the Schluter Dilex. Personally I prefer the caulking, only because it blends in andwon't be noticed. In the pictures below, there are 3 such movement joints. See if you can pick them out.
I'll tell you this much-- all three are from the same floor, and one of the pics has no movement joint in it.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 11-25-2007, 11:03 PM   #14
CCSowner's Avatar
Trade: Tile/Stone
I'll bet you your next pay check I can find those joints hahah.
Adam Forsythe
CCSowner is offline
Old 11-25-2007, 11:22 PM   #15
tile contractor
Yeah, but that's because you caulked em!!
Old 11-25-2007, 11:35 PM   #16
CCSowner's Avatar
Trade: Tile/Stone
I know i'm the best caulker there ever was.....I have one question I thought you did some fancy design in the backsplash.
Adam Forsythe
CCSowner is offline
Old 11-25-2007, 11:48 PM   #17
tile contractor
It's off to the right in the first picture.
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Expansion joints for underground fed meter cans mdshunk NEC Discussion 12 02-02-2007 03:13 PM
Expansion Joints MarvinWilleyJr Painting & Finish Work 0 01-13-2007 11:08 PM
Anchoring in concrete using expansion anchors plazaman General Discussion 1 10-17-2006 09:23 PM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
