Tiling Homes In The Winter Months
Old 02-12-2018, 10:09 PM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 837
I was curious how you guys handle tiling homes specifically existing homes and the extreme cold winter months. Cutting outside with a grinder or even wet saw setup is a huge negative with the temps in the minus 10 to 20. Kitchen glass tile back splashes which I have a few to do are imperative for me to use the wet saw. NO garages for set up etc.. All finished houses. We've had a run of 2 weeks of nasty cold weather with no end in sight. Even at 32 to 36 degrees outside cutting is a no go unless I'm missing something that can work. Plastic parts are brittle. My Lachmond wet saw is pretty good at min. water spray but that makes me nervous setting up in a $30,000 kitchen with tarps on the floor
gowings is offline
Old 02-12-2018, 10:13 PM   #2
tjbnwi's Avatar
Rewards Points: 1,584
Re: Tiling Homes In The Winter Months
I set up in the house.
My wet saw is a TS-60, very good water management.
tjbnwi is online now
Old 02-12-2018, 11:05 PM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 372
We cut inside far more than outside, no matter the temperature. It's a lot more efficient.
Plastic the area as needed and roll with it.
Xtrememtnbiker is online now
The Following 2 Users Say Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (02-13-2018), TNTSERVICES (02-13-2018)
Old 02-13-2018, 12:09 AM   #4
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,834
A snapper is your friend in all temps.
Backslashes I have a table top wet saw.
Bathrooms I setup in the room (shower while doing the floor and floor while doing the shower).
Master bedroom of its a master bath.
Spare bedroom of its a hall bath.
Get a big mud pan to set it in and traps to surround.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following User Says Thank You to TNTSERVICES For This Useful Post:
sparehair (02-13-2018)
Old 02-13-2018, 03:59 PM   #5
gowings's Avatar
Rewards Points: 837
Thanks TNT
I have cut in bathrooms before with tarps on the floors.
Actually worked quite well. Just noticed the water mist in the air.
Now I'm in a $30,000 new 2 yr old kitchen. So I get a little nervous. It was -28 here lately with the wind chill. Even disposing of water pails is a pain in the ass.
That mud pan you guys talk about . I looked on the net, Not finding anything . My saw legs are 48 x 29 to the outsides
gowings is offline
Old 02-13-2018, 05:48 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 8,602
If you look into zipwall systems you could pretty much enclose your saw in a plastic tent and keep all your water inside it
Morning Wood is offline
Old 02-13-2018, 07:22 PM   #7
Mordekyle's Avatar
Rewards Points: 2,868
FWIW I know a tile setter that uses a trough heater (for cattle) in his pan to take the chill off.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
Old 02-13-2018, 09:05 PM   #8
tjbnwi's Avatar
Originally Posted by gowings View Post
Thanks TNT
Google mortar box.
Old 02-13-2018, 09:13 PM   #9
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,249
I just did a full bath in marble with a small saw in a concrete mixing tub from HD. The weather and short days s-CKED.
MarkJames is offline
Mason Looking For Winter Employment RacinMason Help Wanted or Looking For Work 6 11-18-2017 10:35 PM
Completing New Home Construction in Winter bwiab Construction 5 09-19-2017 10:18 AM
Drywall supplies that survive winter freezing? artinall Drywall 6 05-22-2012 04:02 PM
Demand spikes for zero-energy-cost homes AmeliaP General Discussion 8 03-07-2012 06:23 AM
Looking toward winter already.. what are the common equipment failures during winter? nEighter Framing 34 10-03-2009 10:26 AM
