Tiling The Bath - Process/material Improvements
Old 03-26-2017, 09:14 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,418
Whenever I tile, I've always stuck with thinset. Not easy to mix but that grip never seems to release.
Now on a bath - I'm faced with tiling right across the surface of a slab control joint. Isn't there a membrane or matt that can be applied atop the concrete that will greatly eliminate the possibility of cracking (ceramic or porcelain) ?
What might be an improved method over the thinset? High moisture propects... Have never applied a premix directly -- only done corrective work following failure! I know the mixes are easier to work (besides the mixing, they are lighter to lug around - no minor thing as the years press on!)
artinall is online now
Old 03-26-2017, 09:17 PM   #2
Frank Castle's Avatar
Rewards Points: 1,112
Re: Tiling The Bath - Process/material Improvements
Ditra to isolate. Thinset on both sides of Ditra.
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 03-26-2017, 09:34 PM   #3
artinall's Avatar
Over the complete area or only around the joint?
Old 03-26-2017, 09:37 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
I have had similar thoughts/concerns. The last slab tile job, I had a few control joints as well as 1 crack in the slab. The slab was several years old and all cracks/joints were in plane. I filled with Planipatch first. Then I put a heavy coat of crack isolation membrane coating across the joints. Then I tiled as normal. I anxiously await being scolded and corrected by fellow tile guys here...
overanalyze is online now
mstrat (03-27-2017)
Old 03-26-2017, 09:47 PM   #5
Tom M's Avatar
Rewards Points: 6,444
I think you bridge the crack with the membrane but use soft joints on each side of the tile. I would have to look it up but I think thats the deal. Ditra also provides very good details on all kinds of scenarios
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
artinall (03-27-2017), TNTSERVICES (03-27-2017)
Old 03-26-2017, 11:50 PM   #6
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Ditra across the whole field is about the best you can do in that situation IMO
TaylorMadeAB is offline
Old 03-27-2017, 12:57 PM   #7
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,654
Rule: All control joints must be honored.
That means that you can't just tile over them with anything and think you are done. The control joint is there for a reason. If you don't honor it with your finish, you are asking for trouble.
Adhere to EJ171 and the TCNA recommended installation guidelines for tile over concrete. They have tested this more than any of us combined, so there is no reason to try things that someone on the internet said might work.
You can also contact Schluter and get their tech dept to give you recommendations on what products to use. Schluter has some fantastic control/expansion joint profiles.
The 2016 TCNA handbook is a must. Your application starts on page 62.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following 6 Users Say Thank You to TNTSERVICES For This Useful Post:
artinall (03-27-2017), charimon (07-22-2017), CharlieDelta (04-19-2017), mstrat (03-27-2017), overanalyze (03-27-2017), TaylorMadeAB (03-27-2017)
Old 03-27-2017, 09:10 PM   #8
Trade: Renovations
Are we talking control joints or isolation joints? No question that iso-joints need to be continued throughout the floor. I hadn't really considered control joints to be more than a way of choosing where a crack occurs in a slab, if it in fact does crack. I was under the impression that Ditra would allow the slab to shift if needed, but keep that shift isolated underneath.
Old 03-27-2017, 11:35 PM   #9
Hair Splitter
Trade: General
Ditra will only allow so much "shifting" I believe it's 1/8". Any more than that and you create a failure.
But as far as I was taught and know, you respect a control joint, iso-joint, expansion joint...you respect the joint. I would most likely install Ditra on top, but would also install a soft joint.
The Following User Says Thank You to TNTSERVICES For This Useful Post:
TaylorMadeAB (03-28-2017)
Old 03-27-2017, 11:41 PM   #10
...you respect the joint....
And don't Bogart it!
The Following 2 Users Say Thank You to Frank Castle For This Useful Post:
CharlieDelta (04-19-2017), TNTSERVICES (03-27-2017)
Old 04-19-2017, 03:19 AM   #11
Willing2win's Avatar
Rewards Points: 4
I'm with them... Ditra is a great product, a little pricey for some jobs but with the money if you warranty your work and factor it into your bid.
Sent from my Z981 using Tapatalk
Willing2win is offline
Old 07-21-2017, 07:53 AM   #12
artinall's Avatar
If I soft joint it, I believe that it will show against the rest of the grout lines. This is a control joint very prominent across the floor, right after you walk in.
If I understand it correctly, the tile council recommends tile spacing on either side with a wide grout joint. That would be one wide joint.
Old 07-23-2017, 09:36 AM   #13
Hair Splitter
Trade: General
A soft joint is for finished floor material expansion. An expansion joint is for slab foundation movement management.
Old 07-23-2017, 11:11 PM   #14
Itsthetajmahal's Avatar
Trade: Tile installer
Yes if the concrete joint is square with the room that would probably be your best bet to split a fat joint on it if it looks that threatening. I'd go with the detra though
Itsthetajmahal is offline
Old 08-09-2017, 08:54 PM   #15
artinall's Avatar
Going with the ditra - I'm figuring 3/4 total floor height after tile.
The bordering room has carpet.
So I'm looking at finding the best transition to make up the difference in floor heights.
Either a carpet ramp up to it...or something like Schulter Reno? But I really don't know for a carpet layers standpoint how tough it might be to tuck that carpet beneath the metal fold.
Old 08-09-2017, 09:51 PM   #16
tjbnwi's Avatar
Rewards Points: 3,448
Ditra XL will get you to 3/4". If you use XL you need to use a 1/4" notch trowel to set the the XL not the Ditra trowel.
Try to leave the carpet long, roll and staple the edge, set will 2x and rubber mallet.
tjbnwi is online now
TNTSERVICES (08-10-2017)
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1851 09-27-2016 11:09 PM
Poll - Do you give free Estimates? metroconstruct General Discussion 39 06-12-2013 11:18 PM
Charging for Estimates? When should you and how much is reasonable? doby General Discussion 16 06-09-2013 07:04 AM
New Kitchen and Bath designer out of Ocean City, MD saying hi! KitchenScapes New Member Introductions 9 03-19-2013 11:26 AM
Free standing Wheelchair ramp by Creative Bath Systems Creative Bath Specialty Trades Picture Post 5 05-30-2012 05:40 PM
