Trade: Renovations
Tiling Basement Bathroom Floor
Just finish pouring new slab section over new plumbing for a basement bathroom. I have some questions regarding laying tile.
1-The is a fine joint bewteen the old slab and the repaired section of concrete. How do I handle that? 2- The rest of floor is uneven and I need to level, SLC? Can I pour SLC over entire surface and then Ditra? 3-Old slab was painted years ago. How does SLC adhere? 4-Should I use an isolation membrane spanning old and new slab and then lay tile? thanks |
#3 | |
bathroom guru
Re: Tiling Basement Bathroom FloorQuote:
Trade: Tile Sles and Installations
Yeah get rid of the old paint for sure. Use a bonding agent before pouring the slc. If you have a lot of area to do get two guys to help mix the slc or you'll go nuts trying to mix and poor without it drying up on you too quickly.
| Floor fill won't adhere to old concrete floor: help?? | shaane | Flooring | 4 | 12-29-2008 11:21 PM |
| Basement Floor - Settling under slab | mt_42 | Concrete & Paving | 9 | 11-17-2008 12:27 PM |
| Installing tile on a concrete floor in a basement... do I need a membrane? | EZ Mode | Ceramic & Stone Tile | 33 | 05-10-2008 12:56 AM |
| bathroom floor needs replacing | jerry1967 | Flooring | 4 | 09-08-2006 06:00 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
