Trade: Tilesetter
Tiled Shower Leaks...Could Use Any Advise At All...
thanks in advance to all those who take a shot at giving me advice in this situation. This may be more of a plumbing question but since the shower it completely tiled I thought I would try here..
I have a client that recently had their shower built by a contractor a couple of months ago, and now the shower is leaking through the bottom. It leaks occasionally, like once a week, a very inconsistant leak. The 3 x 3 shower was built using black membrane. The floor of the shower seems to be well graded with 1x1 tiles. I can see the leak from under the floor below and is leaking along the side of the drain, and looks to be coming through the membrane and concrete under the tile. I know the abs and drain assembly itself is not the problem. I'm sure the leak is somehow coming through the membrane that the contractor must have not installed correctly. Unfortunately I cant just take the tiles out to fix the membrane as the the contractor poured cement first to grade, then put the membrane, and then cement again ontop to prevent the membrane from floating. anyways, is there any suggestion to how I could fix this leak without having to rip out the intire shower floor? Like i said, the shower was well graded and the drain assembly itself seems to be working and the leak is minimal. I was wondering if I siliconed the grout lines, or maybe i could seal the entire bottom and 6" up the side walls with a very good sealer? Again, any advise or suggestions are much appreciated, Thanks Again, JAY |
Trade: Plumbing & Gas Contractor
Re: Tiled Shower Leaks...Could Use Any Advise At All...
If it's the shower pan you're probably screwed.Was it tested.That's what insurance is for,anything you do will only be a temporary fix, IMO.
Steve
Trade: Remodeling and Custom Cabinets
I 2nd Threaderman's answer. Tear it out or walk away and let someone else fix it. Patching it will give you a life time of callbacks.
Trade: GC/Transportation
have you checked the mixing valve??
I had this problem once, same symptoms, but there was a gasket leak in the mixing valve (behind the tile and in the wall, easy move for water vs. sheetrock). Cracked open the wall in the closet, shut off the water after I determined the source of the leak, drained pipes, Scraped out old putty, changed gaskets, repacked putty, turned on water, no leak. Might be it. |
Trade: Tilesetter
I took off the cover and felt the insulation back there, and its all bone dry..
it could be possible though... makes me wonder? |
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Jay,
A few things you said makes me suggest you brush-up on how a "standard" shower should be built. Go here to review the steps; http://www.ontariotile.com/preslope.html The grading has nothing to do with the leak. Showers should not leak even if all the tiles and deck mud is removed. The membrane prevents water that gets through from ruining the ceiling below. And....yes, there is supposed to be a slope under the membrane too. The entire floor and up the wall at least 8-10" and the curb with have to be removed and redone. It's not so easy to do so it'll look good. We usually run into this type of problem when to shower has had 25-40 birthdays and was not done correctly in the first place. We usually rip it all out and start over, the whole shower I mean. Jaz |
Full Service Renovations
Jay if the shower is only a couple of months old why is the HO not calling the first contractor back to fix this problem?
The advice from the previous posters is correct... anything you do (unless you rip it up and find the source) is just a band-aid and now you own the problem. IMHO any tiled shower should have a KERDI membrane and drain system. Cheers from a fellow Calgarian!! |
Trade: Tilesetter
Thanks for the info guys and I appreciate you guys trying to help me out in this situation. You are right, after I agree to "fix" the problem, it becomes my problem. As for why the HO didn't contact the guy who installed it, I didnt ask, I just assumed they didn't want him back..
Trade: custom home building
agreed that you should start over. However, if you don't want to start over, I would epoxy grout the whole thing.
#10 | |
Trade: Specializing in residential remodeling
Re: Tiled Shower Leaks...Could Use Any Advise At All...Quote:
tile mason
Jay, correctly built shower pans will have a layer of roofing felt (or similar) over subfloor, than a preslope of portland cement and moist sand, then a waterproof membrane that wraps up the studs at least 8" above top of curb, then a final slope of mud and your tile.
The preslope is there to direct water towards the drain. Jaz has some good info in his link to shower pan construction. And he is also correct in the way to remedy the situation: remove wall tile and backerboard at least a foot above top of curb, demo pan tile and what's underneath, down to the subfloor, and start fresh. Sounds like from your observation that there is a preslope and a membrane. I bet the membrane was cut around the drain, and pretty much installed incorrectly. Another cause of shower leaks is the clogging of "weep holes". If you didn't install this, and you don't have enough knowledge in tile shower pan construction, why would you be dealing with this mess? If it is your mess that you created, I suggest you pickup the TCNA handbook, and review the recommended procedure for properly constructing a shower "receptor" (or read Jaz's link carefully). I'm surprised this happened, because pretty much every inspector will have you plug your drain and fill up your pan with water prior to you mudding your final slope. But, there are plenty of shower projects that don't get permits pulled.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more Last edited by MattCoops; 12-09-2008 at 10:05 PM. |
Trade: Tilesetter
im a tilesetter by trade, and I'm a friend of the family and was asked if i could take a look at the leak, so I figured i would post an ad on here to see if anyone knew if something could be done next to the obvious of ripping everything out and starting from scratch..
ive never built a custom shower by myself, and am just going by what i see and am trying to help a customer who knows absolutely nothing about this stuff. am i the right man to fix this job, there probably are more qualified people out there. But i do have an idea of what the problem is, and thought maybe there is a fix... but thanks to all your suggestions, from those of you who do this type of work on a daily basis, i think im going to refer the client to a professional shower installer..as it seems, i can only "band aid" the problem thanks for all your help and advice guys, Very much appreciated. ps. as per the ball test, no i haven't done one, due to the fact im pretty confident the problem isnt the drain assembly as the water is leaking on the outside of the drain.. and as per the inspector question, i havent asked about the permit, but there is always a possiblility the membrane got damaged post inspection. Last edited by Jay22; 12-10-2008 at 02:07 AM. |
#13 | |
Chief Toilet Mover
Trade: Bathroom Remodeling
I guarantee you with enough experience you will find that 90% of assumptions of why or where the leak is end up being wrong. Always test. |
#14 | |
Tile Contractor
Chief Toilet Mover
Re: Tiled Shower Leaks...Could Use Any Advise At All... |
MMC73
Trade: Painting & Tile
Unless the HO is willing to let you rip the existing pan, I would not attempt this. You are looking at a warrently nightmare...he who touches it owns it.
#17 | ||||
tile mason
You say the customer knows nothing, and you're gonna help them, but then again you say: Quote:
And, whomever said epoxy grouting the floor, since when is grout a waterproofing agent?
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
#18 |
Thom
Simple fix:
Put a rain gutter under the drip, pitch the gutter to the outside, problem solved. The guy over at Home Depot should be able to help you out here. |
| What are they doing using my pictures and linking to my site? | Mark Daniels | Technology | 19 | 08-04-2011 07:39 PM |
| Customer has a tiled shower pan leak | nywoodwizard | Plumbing | 6 | 05-12-2008 06:07 PM |
| a pool guy looking for some advise | nadtwins | Drywall | 6 | 04-17-2008 09:04 PM |
| Questions on Tiled Shower | ksensen | Remodeling | 10 | 09-10-2007 09:54 AM |
| Question about shower system... | Knyte260 | Plumbing | 59 | 10-24-2005 06:05 PM |
