Tile Safe Membrane!
Old 08-15-2009, 10:56 AM   #21
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Re: Tile Safe Membrane!
Wow, you're ignorance is truly astounding. The head pressure you refer to in regards to Kerdi has nothing to do with the output of a plumbing fixture. It has to do with a solid column of water pushing down on a seam. To say nothing of the solid membrane.
Also, whatever roofing membrane you supposedly spoke with Schluter about, is not the Kerdi component of the Schluter Shower System. A solid sheet of 8mil polyethylene doesn't leak when you touch it.
HS345 is offline
Old 08-15-2009, 11:04 AM   #22
BCConstruction's Avatar
Trade: Construction
Again dude you clearly know nothing. You dont use 8mil Poly on roofs as it cant breath which then means haveing vents all across the ridge. Head of water has everything to do with how much PSI the Kerdi can handle and it's rated at 5000mm which they advertise their self. No more than 14ft of water pressure(head) as plumbers would call it in the UK.
Some people just have no clue. Again. Kerdi can not take anymore than 14ft of water pressure before it fails. Tanking can tank hundreds. This is why im trying to find tanking. You carry on useing Kirdi.
Mods can you close this thread as i have had my question answered and i no longer need to be explaining how products work to the unknowing.
BCConstruction is online now
Old 08-15-2009, 11:12 AM   #23
Tile Contractor
HS345's Avatar
Kerdi is an 8mil polyethylene sheet, with a bonding floss on both sides. It is not designed for, nor intended for use on a roof.
I don't blame you for wanting this thread closed, I would be embarrassed too.
HS345 is offline
Old 08-15-2009, 02:42 PM   #24
Tile Contractor
Bud Cline's Avatar
OH, Now the water is "pressurized"???? Well why didn't you say so?
Ok I'm outa here but first I need to chime in one more time.
"Head pressure" as it relates to the downward weight of water has absolutely nothing to do with the rating of KERDI. It is two entirely different meausrments.
"Water pressure" as it relates to the force of water travelling through a pipe via community gravity feed, or pumped mechanically by screws or impellars, or driven by supplimental air pressure has absolutely nothing to do with the rating of KERDI. It is two entirely different measurements.
Take anything beyond its limits and it will fail, that's a pretty simple concept.
You are trying to mix apples and oranges to get a chocolate shake. It ain't gonna happen.
OK, I'm done. You go on trying to convince yourself and others that you are the the most informed but the truth is...you aren't understanding the scientific conflicts that are being created when similar terms are used to designate different meanings. Ignorance is truly bliss.
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Tile Over Gypcrete Golden Rule Ceramic & Stone Tile 6 11-26-2010 04:00 PM
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
Installing tile on a concrete floor in a basement... do I need a membrane? EZ Mode Ceramic & Stone Tile 33 05-10-2008 12:56 AM
Floating membrane under Tile mjay Flooring 22 02-09-2006 09:53 PM
